Best way to straighten a Long Series drill
Greensands27/01/2021 15:19:27
449 forum posts
72 photos
As a result of a sudden shift in the clamping arrangements on my topslide I have succeeded in putting a set in a 3/8"Dia x180mm long series drill. Before I resort to some heavy thumping can any suggest a good/the right way to straighten things up?
Andrew Tinsley27/01/2021 15:27:23
1817 forum posts
I would be interested in the answer, I have a slightly bent long series drill. I have tried several ways to straighten it and failed. At the moment it is awaiting conversion to a normal jobber length!
I suspect it is hardly worth the effort depending on the cost of a replacement.
Andrew.
pgk pgk27/01/2021 15:41:01
2661 forum posts
294 photos
Back in my archery days i owned one of this style arrow straightener
The method should be obvious with both bearing blocks moveable and the central DTI lever used to straighten.
I'd guess one could knock up a simple practical version with two bits of scrap drilled to 3/8 on the mill table to find the high spot and then use a blunt rod in the quill to press it back to true...?
pgk
old mart27/01/2021 15:45:19
4655 forum posts
304 photos
Any flat surface will do and some little offcuts of 3mm hardboard as shims. Just find the high spot and press the drill down using one layer of shim at each end. Of course, it depends where the bend is located. If it is near the plain shank, you could hold the shank in the lathe and use the toolpost to push the bend using a soft pusher like a piece of wood. Great patience is needed and you will have to go just past the straight and come back to settle the metal down. If you can use the lathe, make a note of how far you moved the drill and also the ammount of bend still left in and you can reach the yield point without going too far past.
If I was using a long series drill, I would use shorter drills first to get the hole as deep as possible before finishing with the long one.
Greensands27/01/2021 16:39:23
449 forum posts
72 photos
Hi pgk - Tried to open your link but am getting "Secure connection failed". Could you have another look at for me. - thankyou
noel shelley27/01/2021 17:10:34
2308 forum posts
33 photos
Put it on a press and keep on till it is straight using a pair of V Blocks. Noel
Frances IoM27/01/2021 17:21:30
1395 forum posts
30 photos
Greensands - look at what settings you have (?force https) as it would appear that you are requesting a higher level of crypto than the site uses.
pgk pgk27/01/2021 18:40:01
2661 forum posts
294 photos
Posted by Greensands on 27/01/2021 16:39:23:
https://www.merlinarchery.co.uk/aae-arrow-straightener.html
pgk
