Adjustable or straight?
Nick Welburn | 25/01/2021 21:05:01 |
136 forum posts | I’m building a Stuart 10v and undoubtedly other things after. I need some reamers I think and I can’t quite decide whether to be adjustable or straight. it strikes me that straight is much more likely to be accurate? But would adjustable mean I needed less ‘odd’ drill sizes? I only have metrics at the moment. Or am I being naive and with a set of imperial drills I could just drill stuff out? |
Clive Brown 1 | 25/01/2021 21:34:35 |
1050 forum posts 56 photos | I think the choice is between "hand reamers" with a lead-in taper, or "machine reamers" which are entirely parallel. The latter need to be used in a lathe or drilling machine and can ream blind holes as well as through holes. The choice is yours, but I'd suggest that hand reamers are the most useful in model engineering. Buy as you need, good reamers are not cheap. They are useful in certain circumstances, producing a closer sized hole with a better finish than drills. Shop-made D-bits can often do as good a job. I happen to have a range of adjustable reamers, but they are amongst the least used tools in my workshop. Edited By Clive Brown 1 on 25/01/2021 21:35:30 |
Nick Welburn | 25/01/2021 21:42:16 |
136 forum posts | I’m thinking about this set as a solid starter? I assume I need some sort of a handle as well perhaps like a for a tap? |
noel shelley | 25/01/2021 21:45:30 |
2308 forum posts 33 photos | For a 10V I would call tracy tools and but a set of 1/16" to 1/2" by 64ths drill set. with this and odd metrics you will have all you need. IF you want reamers they also do a good set of imp reamers. No connection but there good boys. Noel. |
Andrew Johnston | 25/01/2021 22:05:01 |
![]() 7061 forum posts 719 photos | Adjustable reamers are intended for hand use to ease out existing holes that have become worn or misaligned in preparation for fitting a new pin. They are not intended for precision reaming. For precision reaming I use machine reamers, with parallel shanks, aka chucking reamers. Some have straight flutes and some have helical flutes. On balance I prefer spiral flutes as they're less prone to creating polygonal holes. I never use hand reamers, although I think I've got one somewhere. Andrew |
Nick Welburn | 25/01/2021 22:13:19 |
136 forum posts | Cheers guys. I feel I’m learning a heck of a lot on this forum. Drills ordered, we’ll see about reamers when the time comes. |
Paul Lousick | 25/01/2021 22:14:49 |
2276 forum posts 801 photos | Like Andrew, I mainly use machine reamers. I have a couple of adjustable reamers but rarely use them. Home made D-bits that Clive mentioned can be used instead of a reamer to produce an accurate diameter hole. Also used for making tapered holes. Paul |
Phil P | 25/01/2021 22:16:05 |
851 forum posts 206 photos | +1 for machine reamers. I have both types in most common sizes, but I cannot remember the last time I used a hand reamer in preference to a machine reamer. As for adjustable reamers, they are for bodging holes IMHO and have no place in my workshop, apart from a couple of genuine David Brown ones that I inherited but have never used. Phil |
Jon Lawes | 25/01/2021 22:26:49 |
![]() 1078 forum posts | Just look at the drawings and buy the specific sizes you need; rather than a set of X number of reamers you may never use, just buy specific ones. My Britannia uses 1/8 a lot in the motionwork, so I bought a good quality 1/8 machine reamer and I drill the hole using the milling machine and swap the reamer in without moving anything.
Phil P | 25/01/2021 22:48:31 |
851 forum posts 206 photos | Good advice Jon. Also beware of buying cheap used reamers, they very rarely cut properly and will not give you an accurate hole size. Phil |
duncan webster | 26/01/2021 00:37:29 |
5307 forum posts 83 photos | You don't need reamers to strat with, bore things to finished size using the 4 jaw if necessary. After all you are making bits to fit rather than to precise sizes. The holes for valve gear pins can be drilled slightly undersize and then finished with the correct size drill |
Grindstone Cowboy | 26/01/2021 11:22:06 |
1160 forum posts 73 photos | Apologies if I'm teaching granny to suck eggs, but are you quite clear on what folk are meaning by D-bits? It's not an abbreviation for drill bits which your link and "But you refer to d-bits? Would a decent set like this" seems to indicate. You (may) want these. Hope this helps. Rob
Edited By Grindstone Cowboy on 26/01/2021 11:23:03 |
Former Member | 26/01/2021 11:37:15 |
1085 forum posts | [This posting has been removed] |
Simon Barr | 26/01/2021 17:58:21 |
34 forum posts 18 photos | I needed a 1/4" reamer recently and discovered how much these things can cost when shopping about for one. Instead of buying I just made a D-bit from some silver steel. I turned it to the correct diameter then milled it to half thickness for maybe a 1/4". After hardening and tempering it performed admirably and was a fraction of the cost of buying a reamer as I had the silver steel and all the tools needed to make it. It's certainly worth having a go at making one and I'll just make more as and when I need them. I've made a 5mm and a 1/4" so far with success. You can just see it in the picture, to the left of the left most arm but it's not a particularly great picture. |
Howard Lewis | 26/01/2021 19:52:35 |
7227 forum posts 21 photos | In my limited experience of them, adjustable reamers, possibly by virtue of having straight rather than helical cutting edges, tend toward chatter. Hand or Machine reamers with helical flutes are my choice; and for "one offs" D bits, as already described. I prefer to use reamers in a floating holder, so that it can follow the original hole. (If for some reason, off centre it will behave as a boring tool and produce an oversize bore ). Howard Howard |
Chris Gunn | 26/01/2021 22:09:15 |
459 forum posts 28 photos | It seems adjustable reamers are getting a bit of an unjustified kicking in this thread, so to try and redress the balance, in my experience David Brown adjustable reamers were the reamers of choice at Timson's where I did my time, but as I recall just used in the lathes for reaming holes for ball bearings in gear blanks and the like. We had a tolerance of half a thou. We would drill, then bore, then take out about 10 thou with the adjustable reamer to size. The advantages of the David Brown type included the ability to adjust the reamer when it started to wear a little, and eventually sharpen the reamer blades, and eventually replace them when there was not enough to re-sharpen. I would imagine that solid machine reamers would not last that long machining the EN24 blanks, and replacement expensive while the David Brown reamers would be expensive to buy initially, but over thousands of holes would prove the most economical choice. This is a different scenario to the modellers workshop I know, so I can understand why they are not used much there, but that does not make them a poor tool. I still use the few I have occasionally, useful for any odd sized hole that needs to be dealt with. If I did not already have them, I probably would not buy them. Chris Gunn |
Phil P | 26/01/2021 22:26:14 |
851 forum posts 206 photos | I think of these horrible things when someone mentions adjustable reamers. Phil |
Nigel McBurney 1 | 26/01/2021 22:50:43 |
![]() 1101 forum posts 3 photos | In My experiece Adjustable reamers were mainly used by the motor trade for sizing various bushes in gear boxes,steering gears, and other parts where new bushes ,nearly all bronze ,were pressed into their housings .Always supposed to be a hand tool,many mechanics have tried them in drilling machines,but with no real success, there is a knack to using them and one chap I knew was really good as he had a job reconditioning lorry steering gears. I have a lot of them but rarely use them. For reaming I prefer machine reamers with spiral flutes ,particularly on small holes,with larger holes I prefer boring holes rather than reaming,I find that a reamer will pick up and damage the finish whereas boring will produce a better finish. Reamer pick up can be a problem with one offs even industrially,a lot depends on the reamer condition,lubrication speeds and feeds,no problem when there are thousands of say bushes to be made,and a couple of scrappers inset dont matter, |
Nick Welburn | 26/01/2021 23:00:51 |
136 forum posts | Slightly overwhelmed with the responses here. I’ve order a good set of drills from Tracy tools. I now understand reamers and what sort I need. It seems every question has a sub question to it! Thanks again for the guidance. I’m well through making the flywheel now and loving the intellectual and physical challenges that machine work brings. |
Jeff Dayman | 26/01/2021 23:43:29 |
2356 forum posts 47 photos | If a hole must be reamed to an odd size there is also the homemade toolmaker's reamer, nothing but a piece of drill rod / silver steel the right dia with an angled cutting face between 10 to 15 deg ground on, then the rod is hardened. https://www.homemadetools.net/homemade-toolmaker-s-reamer They leave a beautifully finished truly round hole if made well, are dead simple and dirt cheap. |
