A not-so-new Pendulum formula
Michael Gilligan09/01/2021 00:13:33
23121 forum posts
1360 photos
As we have several members interested in Pendulum Clocks, I thought I would share this [which I only stumbled-across today] : **LINK**
http://leapsecond.com/hsn2006/pendulum-period-agm.pdf
Gary Wooding09/01/2021 07:56:02
1074 forum posts
290 photos
Fascinating.
David Millar 309/01/2021 09:06:00
28 forum posts
That's brilliant. I hadn't heard of a geometric average before. Everyday's a school day!
Michael Gilligan09/01/2021 09:20:54
23121 forum posts
1360 photos
I did a quick check ... and he’s right about the Means converging in just a few iterations star
So this looks like it might be very useful indeed
< click for larger image >
Martin Connelly09/01/2021 09:23:46
2549 forum posts
235 photos
I'm being picky but:
Even though the formula is exact as soon as you start calculating the mean of a rational and an irrational number it loses this exactness. It is only exact as long as you compute the square roots to an infinite number each time (unless the number is a perfect square to start with). As long as the irrational numbers are truncated it is still an approximation. It may be a good and useable one but perhaps this approximation in the calculation should have been pointed out in the written paper.
Martin C
John Haine09/01/2021 10:28:51
5563 forum posts
322 photos
It's worth noting that for practical clock pendulum amplitudes, say up to 10 degrees, the difference between the AGM formula and the usual "A^2/16" approximation to the circular deviation is very very small: 3.3 usec for a 1 second period and 10 degrees. I've done pendulum simulations for the order of amplitude used in "Clock B" and compared them to simple formulas based on the same approximation with virtually identical results.
Where the AGM really is useful is for methods where you need to quickly compute elliptic integrals. One example is designing very selective LC filters, where there are formulas for the component values that incorporate elliptic integrals. Once you needed to have extensive tables of these, but now they can be calculated more accurately in a few lines of code.
Michael Gilligan09/01/2021 10:37:50
23121 forum posts
1360 photos
Very true, Martin .... but this does get us [with very little effort] several orders of magnitude beyond the classic ‘simplified formula’ which only works for small swings.
What excites me about it is that it’s accurate [or trivially inaccurate] for large angles.
P.S. __ The title of the original 2008 paper [see Further reading] is:
Approximations for the period of the simple pendulum based on the arithmetic-geometric mean
Edit: ___ The link appears to be dead, but this one works for me:
https://www.researchgate.net/publication/228353411_Approximation_for_the_period_of_the_simple_pendulum_based_on_the_arithmetic-geometric_mean
Edited By Michael Gilligan on 09/01/2021 10:55:24
Michael Gilligan09/01/2021 10:44:24
23121 forum posts
1360 photos
Posted by John Haine on 09/01/2021 10:28:51:
It's worth noting that for practical clock pendulum amplitudes, say up to 10 degrees […]
I am particularly interested in larger swings than that, John
Huygens, Harrison, et al ... [pendulum has ‘dominion’ and all that]
MichaelG
