Looking for advice from anyone who has had a copper boiler fail after using silfos especially in the firebox.ure
Andrew Binning | 05/01/2021 21:31:27 |
![]() 39 forum posts 9 photos | I have acquired a boiler which is at least 10 years old and the firebox silver soldering may have been done with silfos - 15. The phosphorus content of this alloy makes flux unnecessary but the phosphorus is attacked by the sulphur from the coal combustion and eventually the joints will go spongy and porous. Data sheet warnings for this brazing alloy warn against the use in a sulphurous environment. The boiler has not been steamed and while it passed a hydraulic test when it was built it now has a number of small leaks on the inside ends of the firebox stays which are threaded gunmetal. I am looking for advice on how to proceed as I need to seal the joints in the best case or , in the worst case , I can prove that silfos was actually used, then the boiler may have to be scrapped. |
Former Member | 05/01/2021 22:12:11 |
1085 forum posts | [This posting has been removed] |
Andrew Binning | 05/01/2021 22:32:26 |
![]() 39 forum posts 9 photos | Thank you for your suggestion I have already had discussions and sought advice from Johnson Matthey, Cup Alloys and my Club Boiler inspectors. No clear consensus on best course of action yet, hence throwing the problem to a wider audience in the hope that I can pick up the best advice. The problem is the original boiler maker is now in his eighties and he is not 100% sure what he used. He still has a stock of Silfos from a project in the Nuclear industry where fluxless brazing of large copper conductors was required. He thinks he may have used the silfos in the firebox but not on the outside joints. Not sure why he did it this way around. If I could be sure that the firebox stays in the firebox ( which are threaded gunmetal ) were not soldered using silfos I would be happy. I still have some small leaks but they can be sealed hopefully. |
Andrew Tinsley | 05/01/2021 23:08:34 |
1817 forum posts 2 photos | If it comes to scrapping the boiler, maybe think of using gas firing rather than coal? Just a thought. In the longer term I think there are major advantages in using propane in any case. I am seriously looking at doing so on the two locos that I am building. Andrew. |
Keith Hale | 06/01/2021 08:24:00 |
![]() 334 forum posts 1 photos | Hi Andrew, Check out my profile and if you feel it's relevant then consider the content of the personal message. I can honestly say that in my 50+ years in the brazing business, I have not come across a situation where anyone has felt the need to rectify a copper/copper joint, previously made with Silfos type materials, with either silver solder or soft solder. There is a very simple and quick way to answering the question. Clearly you cannot consider a phosphorus bearing alloy for repairing your leaks. Regards Keith |
Former Member | 06/01/2021 08:44:45 |
Keith Hale | 06/01/2021 09:00:18 |
![]() 334 forum posts 1 photos | Wow! Sorry br, I can't be more friendly, but thank you for your comment. Keith
Edited By Keith Hale on 06/01/2021 09:28:11 |
SillyOldDuffer | 06/01/2021 10:40:07 |
10668 forum posts 2415 photos | Few thoughts from an outsider - feel free to disagree!
Dave Edited By SillyOldDuffer on 06/01/2021 10:43:42 |
Andrew Binning | 06/01/2021 18:02:27 |
![]() 39 forum posts 9 photos | Thank you all for your responses and suggestions. I am concerned about the possible use of Silfos in the firebox because of the possible failure under working conditions i.e. sulphur attack on the phosphorus fluxed alloy. The good news that the stays are gunmetal and were threaded into the inner firebox sheets. I only have leaks on the side sheets in the firebox. Mechanically the silfos joints will be strong enough because of the threaded stays although some might leak in due course. Perhaps hard water scale will keep those leaks at bay? My original post was to invite suggestions for repairing the leaky stays. As the Moderator has suggested the Silfos is to a certain extent a red herring because for the purposes of repairs, 455 silver solder will be OK according to Johnson Matthey. Talking to CuP Alloys they felt that if the internal firebox stay ends had been soldered with Easy Flo No. 2 there might be a risk in using 455 for repairs because of the higher melting point and the risk of melting nearby stays that are pressure tight at the moment. The leaks are fairly minor ( slow bubbling with 40psi air pressure ). I have Oxy/Propane equipment and am looking into getting a cylinder of Propylene which has a higher calorific value than Propane but safer than Acetylene. Propane as a source of heat is an interesting idea but I have no experience of burners, fuelling techniques, etc. I am happier sitting on a tender of coal rather than a gas cylinder. Also has been pointed out it doesn't smell right!! I have not messaged Keith Hale directly because I feel we can all benefit from the experience of his years of experience in these matters if he cares to reply in the forum. I would though be interested in seeing what Keith suggests I use to seal these leaks and out of interest is there anyway that the actual joint alloy could be sampled? I don't know anyone with access to a mass Spectrometer! |
Dave Halford | 06/01/2021 18:13:10 |
2536 forum posts 24 photos | Posted by Andrew Binning on 06/01/2021 18:02:27:
I don't know anyone with access to a mass Spectrometer! A jeweller who buys old gold |
Keith Hale | 07/01/2021 09:14:58 |
![]() 334 forum posts 1 photos | Hi All, Add to the list of lifes certainties; Flat roofs leak and Leaks in a brazed joint are caused by operator malpractice. (No exceptions!) Refer to BS EN 14324 Guidance on the application of brazed joints. -----+++------ Mass spectrometers in a jewellers or pawnbrokers? They use hallmarks and trust/gamble on what an experienced eye tells them Keith
Dave Halford | 07/01/2021 12:19:09 |
2536 forum posts 24 photos | Posted by Keith Hale on 07/01/2021 09:14:58:
Hi All,
Not in the Birmingham Jewellery Quarter Keith. Too much Asian unmarked gold. |
