chuck removal from speed reducer
sparky mike04/01/2021 15:06:41
259 forum posts
77 photos
I have a Mason Master drill speed reducer and I wish to remove the chuck, a Jacobs Multicraft M6CG61. Having a problem shifting it. Are these screwed on or tapered ?
Mike.
John Rudd04/01/2021 15:10:09
1479 forum posts
Screwed on.....
I currently have one disassembled...
That is how I know.
Edited By John Rudd on 04/01/2021 15:11:15
sparky mike04/01/2021 15:14:52
259 forum posts
77 photos
Thanks John,
Thought it might be but was not sure.
How did you remove it ?
Mike..
Brian Morehen04/01/2021 15:25:29
191 forum posts
11 photos
Close the chuck jaws up Fit the chuck key as if you where using some to tighten hold the wheel and give the chuck key a sharp tap job done chuck loosened.
Regards Bee M
sparky mike04/01/2021 16:39:04
259 forum posts
77 photos
It is now removed. Thanks for info above. A chuck key did not work, but a good sized allen key tightened in the chuck jaws and then a good hit on that did work. 3/8 UNF thread.
I can now turn up a tapered mandrel with that size thread on other end to fit the small lathe I am restoring.
Mike.
Howard Lewis04/01/2021 16:55:33
7227 forum posts
21 photos
Thanks for telling us that you have succeeded, and what thread to expect!
