Warco UNIVERSAL TOOL & CUTTER GRINDER v Quorn Mk 3
John Harris 101/01/2021 17:33:49
11 forum posts
Hello
Moving up to accurate tool sharpening. Have come down to two options which both on the face of it do exactly the same - Warco UNIVERSAL TOOL & CUTTER GRINDER v Hemingway;s Quorn Mk 3. One, in theory, comes ready to grind, the other needs a few hundred hours of work before its ready to sharpen the first tool. Is there any advantage with the Quorn Mk 3, other than get it right and you have a Royals Royce machine. And is the Warco a sound, robust machine as it seems to built under a number of guises, but is ready to go.
Third option is the Hemingway's Worden Mk3 Tool & Cutter Grinder which requires some work but is not a major project and is nice and compact, but seems very pricy compared with the Quorn.
I will be sharpening all types of lathe tool, milling cutters, slitting saws and drills.
All advice welcome. Thank you.
Rockingdodge01/01/2021 18:37:43
396 forum posts
111 photos
As an alternative Harold Hall details his offering from bar stock - Tool and Cutter Grinding Head, The workshop practise series 38 is a step by step build of it.
Roger
John Harris 101/01/2021 18:54:28
11 forum posts
Hello Roger
Many thanks. This looks more in my range. Will get a copy of Harold Hall's book. Importance is to be able to touch up tools on a regular basis, and if it can be done without purchasing a Royals Royce option all the better.
Again thanks, John
Baz01/01/2021 20:04:38
1033 forum posts
Another possibility is the Acute sharpener from Eccentric Engineering.
John Harris 101/01/2021 21:29:49
11 forum posts
Thanks. Have just looked at their website and they do have a UK distributor.
Henry Brown01/01/2021 21:32:50
618 forum posts
122 photos
Don't forget to benchmark the Stent against the Quorn if going that way...
bernard towers01/01/2021 22:12:21
1221 forum posts
161 photos
Yes Henry beat me to it, wouldn’t be without mine not so many ball handles!!!
