Terry Chapman | 17/12/2020 11:02:43 |
![]() 97 forum posts 14 photos | Hi,Thinking of modifying my 3/4" Holden showmans to gas? I ve just started building and Ive found theres no way to drop the fire in case of problems soWas thinking about gas? Has any one done this how and what do I need please? Thanks |
Oldiron | 17/12/2020 12:03:10 |
1193 forum posts 59 photos | Sorry not done a gas conversion myself. I believe there is a company called BIX and probaly others that do gas burners for minitures. You can find them via Google or there are some YT videos about them. Good luck with the build. regards |
Henry Artist | 17/12/2020 12:36:43 |
![]() 121 forum posts 46 photos | Using gas offers some significant advantages. You can run a boiler indoors and the heat is instantly controllable. Also, no smoke, soot, or bad smells. I would strongly urge you to telephone Phil at Forest Classics to discuss your requirements. |
Former Member | 17/12/2020 12:53:01 |
1085 forum posts | [This posting has been removed] |
Former Member | 17/12/2020 13:36:10 |
Terry Chapman | 17/12/2020 13:40:29 |
![]() 97 forum posts 14 photos | thanks all for your help. Terry |
Terry Chapman | 21/12/2020 08:49:58 |
![]() 97 forum posts 14 photos | Posted by br on 17/12/2020 12:53:01:
Terry Holden build instructions for the gas fired version are in the kit - or should have been, as your model, like my version,, was sold as gas fired or coal. The input is half way up the tender and looks rather ugly so to my mind needs re-thinking. The gas supply was carried in the living van that he sold for the gas powered version - easy enough to make as is all plywood construction and uses mamod wheels. br Hi,nothing in the instruction sheets except to leave the pump off if gas powered???
Ady1 | 21/12/2020 09:08:39 |
![]() 6137 forum posts 893 photos | The indoor steam guys would probbly be able to help you I was very impressed with a small show I visited Edit: there is also spirit powered steam There's deffo an active market out there Edited By Ady1 on 21/12/2020 09:40:33 |
