Citric Acid Pickle Question
Blue Heeler17/12/2020 03:41:09
342 forum posts
G'day all,
Would a Citric Acid Pickle solution in an open bucket be just the same as saltwater ie only the water will evaporate?
Pero17/12/2020 05:50:53
193 forum posts
You will lose a little through evaporation. Quick test - if you can smell it, then there is some present in the evaporating water - the stronger the smell the more acid that is present in the vapour. However the human nose is quite sensitive and it takes relatively few molecules for the brain to register its presence.
In this instance the bulk of the acid will slowly concentrate in the reducing water volume.
Pero
Speedy Builder517/12/2020 06:27:34
2878 forum posts
248 photos
AND don't have the pickle in your workshop - how did I know that !!!
Rusty Miller
Simon Collier17/12/2020 06:38:47
525 forum posts
65 photos
Citric acid grows bugs unless you take measures, like putting a bit of bleach in it. I use it for small brass fittings in the workshop but for anything larger, it goes in the sulphuric outside the workshop. I make fresh small amounts of citric if it has been more than a few days. The real nightmare in the workshop is HCl, as in Bakers fluid.
Ian B.17/12/2020 08:12:09
171 forum posts
5 photos
Nor keep ferric chloride for your pcbs within 100 yards of your workshop. Dont ask!.
Ady117/12/2020 09:14:05
6137 forum posts
893 photos
Check anything in the bucket every day, every single day, or things can quickly go too far. Don't ask!
larry phelan 117/12/2020 14:14:58
1346 forum posts
15 photos
Bubble Bubble Toil and Trouble ??cheeky
