Discrepancies in drawings
Nick Clarke 2 | 16/12/2020 13:01:06 |
20 forum posts 3 photos | Hi, I am about to pull the trigger on the 2 inch scale Dairy Engine but before I d I need a little advice. According to the drawings it would be impossible to fit the grate, which is 3 3/4 inches in diameter, into a space only 3 5/32 diameter. the written notes say the grate sits on top of the boiler feet but I cannot see how. If anyone has built one of these little engines, some guidance would be well received, or in fact any advice at all would be most helpful. I have attached the relevant parts of the drawing... Edited By Nick Clarke 2 on 16/12/2020 13:02:26 |
JasonB | 16/12/2020 13:25:44 |
![]() 25215 forum posts 3105 photos 1 articles | Looks like it should be about 3" dia or a little less so it does not get stuck in there. Are you going to risk buying a set of castings or fabricate? |
Nick Clarke 2 | 16/12/2020 13:55:50 |
20 forum posts 3 photos | Posted by JasonB on 16/12/2020 13:25:44:
Looks like it should be about 3" dia or a little less so it does not get stuck in there. Are you going to risk buying a set of castings or fabricate? Hi, I was going to buy a set fo castings from a chap in the midlands. What is the risk in using castings? It would be far easier for someone of my limited experience to use castings. I was thinking of lifting the foundation ring and drain plug by 3/8" and shortening the firebox pro rata to accomodate the grate. Many thanks for your reply, Nick. |
Dave Halford | 16/12/2020 13:57:46 |
2536 forum posts 24 photos | Nick, Don't be surprised if some details are not included in the drawings at all. |
JasonB | 16/12/2020 13:59:45 |
![]() 25215 forum posts 3105 photos 1 articles | Quite a few people have had problems getting castings from the only supplier of these that I know so depends who your "chap" is but you may want to search this and other forums for threads about them. Rather than lift the foundation ring I think I would just make the barrel longer so you have some material projecting down below and then the grate would fit in OK.
Edited By JasonB on 16/12/2020 14:04:59 |
Nick Clarke 2 | 16/12/2020 14:02:55 |
20 forum posts 3 photos | Posted by JasonB on 16/12/2020 13:59:45:
Quite a few people have had problems getting castings from the only supplier of these that I know so depends who your "chap" is but you may want to search this and other forums for threads about them. Ok, thanks I will look in to it. I didn't mention the name as not sure about promoting commercial suppliers. |
Former Member | 16/12/2020 14:51:18 |
1085 forum posts | [This posting has been removed] |
Former Member | 17/12/2020 08:34:28 |
JasonB | 17/12/2020 08:50:30 |
![]() 25215 forum posts 3105 photos 1 articles | There is also Anthony Mount's "Verto" from Polly who are OK to deal with. Or as BR says any combination of a vertical boiler and suitable engine would make up into something similar though I would probably cut the base from a piece of 12 or 16mm aluminium plate and mill a moulded edge onto it. |
Former Member | 17/12/2020 08:59:28 |
