UncouthJ | 28/11/2020 11:24:46 |
143 forum posts 39 photos | Hi folks. I’m looking to make some trench lighters as a starter project. Can anyone recommend any reading material on how different metals react with substances, fuels in this case? Any quick and easy go-to resources much appreciated. I’m desperately trying to avoid breaking out the materials-science textbook from college days if I can possibly avoid it... Cheers
Henry Artist | 28/11/2020 16:53:55 |
![]() 121 forum posts 46 photos | Many have looked at this thread but none have bitten so I'll have a go... The liquid fuel most commonly used in lighters with a wick and flint ignition is called, unsurprisingly, "lighter fluid" (a.k.a. Zippo fuel, Coleman fuel, light naphtha, etc.) and does not react adversely with any metal or solder you could conceivably build such a lighter from. Any type of brass can be used though a free-machining one like CZ121 might be preferable. |
Steviegtr | 28/11/2020 16:56:58 |
![]() 2668 forum posts 352 photos | Ah now i understand the question. Thought trench lighters were something other than a cigarette lighter. Doh. I even thought it must have something to do with a steam engine. Steve. |
Howard Lewis | 28/11/2020 17:14:55 |
7227 forum posts 21 photos | As I understand it, Trench Lighters were often made from discarded 0.303 bullet cases. My turning Instructor made his rectangular lighter, during wartime night shifts, on a capstan lathe. Asked how he made something rectangular on a lathe he said "Hold it in the toolpost and use an End Mill in the chuck" Howard |
SillyOldDuffer | 28/11/2020 17:35:08 |
10668 forum posts 2415 photos | I've never come across a simple reference. My books all assume enough Chemistry is understood to join the dots. My Materials Books (two!), are mostly about physical properties and don't help. Roughly though:
So making a trench lighter, the metals aren't a concern. Any brass will do, with soldered joints to make it leak-proof. But watch out for everything else. Lighter fuel is fairly likely to have a go at rubber, plastics, wood, and glue etc. As its also likely to escape through anything porous, brass is a good choice - any brass, though I'd go for one that's easy to work. I guess most original Trench Lighters were made from Cartridge Brass, which is very ductile after annealing and easy to work. Dave
UncouthJ | 28/11/2020 18:06:58 |
143 forum posts 39 photos | Well thats nice and simple then. Thanks gents. |
Oily Rag | 30/11/2020 14:15:23 |
![]() 550 forum posts 190 photos | Reminds me of the joke my father used to tell about a visit from Lord Beaverbrook (Min. of Aircraft Production - MAP) around sometime in 1940 to the Armstrong Siddley works at Bagington. He approached a bench fitter and asked him "...how many fighters have you produced tonight?" "38, sir" came the reply. "That's amazing" said Beaverbrook "keep up the good work" - then the fitter said " you did say lighters, didn't you?"
