peak4 | 25/11/2020 15:37:17 |
![]() 2207 forum posts 210 photos | Hello, Does anyone have an older Dremel Moto-Tool Model 358-5 variable speed, and who is able to have a look inside to confirm a component number please . Cheers |
Grindstone Cowboy | 25/11/2020 17:49:55 |
1160 forum posts 73 photos | Sorry, just checked and mine is Mod 395 Type 5, but happy to have a look if it might help? Rob |
peak4 | 25/11/2020 19:26:01 |
![]() 2207 forum posts 210 photos | Posted by Grindstone Cowboy on 25/11/2020 17:49:55:
Sorry, just checked and mine is Mod 395 Type 5, but happy to have a look if it might help? Rob Many thanks, but it looks to work a different way. |
Grindstone Cowboy | 25/11/2020 21:55:28 |
1160 forum posts 73 photos | Yep, probably no use at all, but I took it apart anyway so I could brush the dust out. There is something in there marked BT134W, with three legs and a heatsink/mounting tab. Surface mounted device, Googled it and it's a triac. Surprisingly it still works after re-assembly Rob Edit - Maybe in a circuit similar to this? Edited By Grindstone Cowboy on 25/11/2020 22:09:02 |
peak4 | 25/11/2020 22:35:14 |
![]() 2207 forum posts 210 photos | Posted by Grindstone Cowboy on 25/11/2020 21:55:28:
................................. Googled it and it's a triac. ............................. Edited By Grindstone Cowboy on 25/11/2020 22:09:02 Cheers, and I'm glad you didn't break it.
Edited By peak4 on 25/11/2020 22:38:23 |
Bazyle | 25/11/2020 23:56:59 |
![]() 6956 forum posts 229 photos | Not related to your problem directly but on the subject of Dremels today on the SADMES zoom chat one of our members mentioned that the motor wires in some of these drills are connected by insulation displacement connectors which result in a nick in the wire that eventually then breaks the wire owing to vibraton. So a complete failure might be due to that. Be aware. |
Robert Atkinson 2 | 26/11/2020 07:51:40 |
![]() 1891 forum posts 37 photos | A l7805 is a 5V DC regulator. Most certainly the wrong device for a 240V universal motor. Can you post a photo of what is there already? Another option would be to use a basic light dimmer in series with the tool. (Use an earthed metal back box, proper strain relief on cables). Robert G8RPI. |
peak4 | 26/11/2020 13:19:17 |
![]() 2207 forum posts 210 photos | Posted by Robert Atkinson 2 on 26/11/2020 07:51:40:
A l7805 is a 5V DC regulator. Most certainly the wrong device for a 240V universal motor. Can you post a photo of what is there already? Another option would be to use a basic light dimmer in series with the tool. (Use an earthed metal back box, proper strain relief on cables). Robert G8RPI. Yes, tried contacting Dremel UK, which seems to take you to Bosch Hello, US Dremel takes you to an auto-chat, which doesn't recognise anything relevant that I type, and the email help option directs you back to the UK as I don't have a valid US address for it to check. I've a Lidl light dimmer which does the varispeed quite well, but was just seeking to fettle the Dremel itself as the spare bedroom electronics workshop is warmer than the garage metalwork one. Bill |
Grizzly bear | 26/11/2020 20:13:53 |
337 forum posts 8 photos | Hi peak4, Please keep us posted. Mine is a 300 series, willing to help, if required. Bear.. |
peak4 | 26/11/2020 21:16:11 |
![]() 2207 forum posts 210 photos | Thanks for the offer of assistance folks, a slight delay in the presentation. It all took slightly longer to draw than I'd planned. Edited By peak4 on 26/11/2020 21:17:43 |
peak4 | 30/11/2020 14:34:30 |
![]() 2207 forum posts 210 photos | Final update folks, Semiconductors now replaced with Diac and Triac and I now have a vari-speed Dremel again. |
Michael Gilligan | 30/11/2020 14:39:27 |
![]() 23121 forum posts 1360 photos | Well done, Bill Previous owner led you on a merry dance there !! MichaelG. |
peak4 | 30/11/2020 15:04:30 |
![]() 2207 forum posts 210 photos | Posted by Michael Gilligan on 30/11/2020 14:39:27:
Well done, Bill Previous owner led you on a merry dance there !! MichaelG. To be honest, trying to post the circuit diagram above was far more taxing than the repair. Bill |
HOWARDT | 30/11/2020 15:18:20 |
1081 forum posts 39 photos | I have bought Dremel spares from a shop in Derby that comes up when I search for them in the UK. At the moment I run two, one of which I had to replace the bushes and the nylon tube spindle drive, I think that one dates back to the 90’s after my first one from the seventies gave out. |
