Lee Jones 6 | 24/11/2020 20:04:58 |
258 forum posts 125 photos | Just searching one of my usual places for picking up indexable tooling. Looking for an indexable chamfer cutter this time around. Stumbled over Link removed see CofC seller and was blown away by the choice. Despite the obvious diameter/angle differences, why would you choose one of these styles over the other? I'm particularly interested in the rectangle (APMT) vs triangle (TCMT) variants. Edited By JasonB on 24/11/2020 20:12:29 |
JasonB | 24/11/2020 20:15:19 |
![]() 25215 forum posts 3105 photos 1 articles | Single triangle will usually go down to a smaller size hole or radius Square can often be used above and below the work without changing tool 2 or 3 insert allow faster feed rates for same given chip load over single insert but minimum radius goes up. |
JasonB | 24/11/2020 20:18:22 |
![]() 25215 forum posts 3105 photos 1 articles | Hass explain it quite well in this video |
Lee Jones 6 | 24/11/2020 20:18:50 |
258 forum posts 125 photos | That's what's confusing me the most, both S and T have the same min-radius. |
old mart | 24/11/2020 20:36:25 |
4655 forum posts 304 photos | I've got one that is adjustable for angle. |
Lee Jones 6 | 24/11/2020 20:38:00 |
258 forum posts 125 photos | Oooo, posh. How does that work? |
JasonB | 24/11/2020 20:43:28 |
![]() 25215 forum posts 3105 photos 1 articles | |
Lee Jones 6 | 24/11/2020 20:59:02 |
258 forum posts 125 photos | A (moving) picture paints a thousand works. Thanks a bunch. |
old mart | 24/11/2020 21:03:35 |
4655 forum posts 304 photos | I can't post a pic of the adjustable chamfer tool as it is locked up at the museum at the moment. It is a WNT and the single sided positive insert sits in a holder that pivots around the central hole in the insert. SAU also make the same type. Some use triangular inserts, and some square ones. |
Michael Gilligan | 24/11/2020 21:33:59 |
![]() 23121 forum posts 1360 photos | An insert for an insert ...That’s neat. MichaelG. |
