Steve Sedgall 1 | 17/11/2020 08:33:50 |
2 forum posts | Is there a "special" forumula for getting a bright finish on aluminium?? |
Stuart Bridger | 17/11/2020 08:41:10 |
566 forum posts 31 photos | Turning?, Milling? Polishing? |
SillyOldDuffer | 17/11/2020 09:17:23 |
10668 forum posts 2415 photos | Do you mean keeping a bright polished finish rather than a good machined finish, ie one free of tool marks? A problem and virtue of Aluminium is it reacts quickly with Oxygen in air. The reaction creates a thin surface oxide layer that stops further action, so the metal is self-protecting, which is good. Unfortunately the oxide layer is dull grey and tends to spoil the appearance. For decorative purposes Aluminium is often anodised, where a simple electrical process thickens the oxide layer and embeds coloured dye in it. Hard to keep a mirror finish on Aluminium. As far as I know, it can only be done by immediately varnishing the polished metal with a clear lacquer. Or, in the case of mirrors, air is kept away from the shiny surface by the glass. Dave
Oven Man | 17/11/2020 09:20:40 |
![]() 204 forum posts 37 photos | Yes, the grade of aluminium is very important, just like steel. Some bar I recently bought gives a terrible finish that looks like tearing, but the same milling cutter under the same conditions on another piece produces a brilliant finish. Peter |
Mike Hurley | 17/11/2020 09:26:08 |
530 forum posts 89 photos | If a turned piece, the a fine 'Scotchbright' type material used while inthe lathe polishes a treat. Otherwise the same with elbow grease if flat /irregular. Agree about oxidation though, so clear lacquer may be your only option to retain the finish in the long term. |
John Haine | 17/11/2020 09:55:53 |
5563 forum posts 322 photos | Or Renaissance A+Wax. |
Neil Wyatt | 17/11/2020 11:31:49 |
![]() 19226 forum posts 749 photos 86 articles | Very highly polished aluminium will keep a shine for several years if kept clean, even though it will develop an oxide layer. With a well polished surface this is very thin and barely reduces the reflectance. Think aluminised telescope mirrors (you can get them overcoated, but this is often not done as it costs extra). Results do vary according to grade and an overcoat of polish should help preserve the shine under real world conditions. As random example, our back door handle lost most of its anodising years ago, and the worn parts are mirror bright. Neil |
