Here is a list of all the postings Steve Sedgall 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Aluminium surface finish |
17/11/2020 08:33:50 |
Is there a "special" forumula for getting a bright finish on aluminium?? |
Thread: Reaming - depth of cut |
05/11/2019 09:15:05 |
Just to add to the confusion the more material the reamer has to remove the bigger the reamed hole will be. Also the speed of the reamer/work will have an effect on overall size. Fast surface speeds will produce a hole bigger than slower speeds. As my old mentor used to say if you have a surface finish/size issue then check your roughing tool first. |
