George Maclean | 25/10/2020 18:15:32 |
4 forum posts | Hi have a CVA !A series and I believe the correct travelling steady. But there are no tapped holes or dowels in the cross slide to bolt in on. Anybody there with one fitted or experiences fitting one photo appreciated,
Thanks George.// |
David George 1 | 26/10/2020 08:57:18 |
![]() 2110 forum posts 565 photos | Hi George have you looked at lathes.co.uk as there is a couple of pictures on there and it looks like they are fastened into a T slot on the top slide. http://www.lathes.co.uk/cva/ David Edited By David George 1 on 26/10/2020 08:58:29 |
DC31k | 26/10/2020 09:16:55 |
1186 forum posts 11 photos | It would be unworkable to have tapped holes in the cross-slide for a travelling steady as it would be difficult to centre when setting up and would change position every time you put on a cut. The mounting points will be in the saddle of the machine. As David says, look on the lathes site: the one picture there that shows the travelling steady has it bolted to the tailstock side of the saddle - it spans over the cross slide. Maybe also look at pictures of the Monarch 10ee for guidance as the CVA has some similarities to that machine. |
George Maclean | 26/10/2020 17:58:29 |
4 forum posts | Hi Guys, Thanks for the replys ( I meant saddle !) have been to Tony' s site, The single arm follower if that what it is on the earlier machine round machine is on the side of the saddle.. The later photos series 1A-3 further down the pages show what I have . I have the parts list PD1182 Original manual D M Cole and Sons the Dorking address It's fixed by four bolts two either side or two could be dowels but parts manual indicates bolts. Just wondered if these lathes only came out of the factory set up only for the acessories bought at the time of purchase? Somebody must have a travelling steady in action??, Any one need a copy of the parts manual can do at cost. Thanks for the replys George.// PS Can I upload pic's ?
Oldiron | 26/10/2020 18:59:11 |
1193 forum posts 59 photos | Posted by George Maclean on 26/10/2020 17:58:29:
Hi Guys, (---) PS Can I upload pic's ? Guide here --> Posting pics |
Dave S | 26/10/2020 20:55:37 |
433 forum posts 95 photos | On mine there are a pair of hole on the chuck side and a pair on the tail stock side:
I have no travelling steady, only the fixed one. Dave
George Maclean | 26/10/2020 21:26:42 |
4 forum posts | Thanks, Dave Says it all no holes or little bosse's on mine, Thanks again.
Dave S | 27/10/2020 12:20:02 |
433 forum posts 95 photos | Does that mean you have a travelling steady for sale then? Dave |
Martin Nichols | 08/03/2021 13:23:22 |
1 forum posts 6 photos | Bit late here, but I've emailed George directly with positions & dimensions of holes. Here's mine in-situ with the top-slide removed for clarity:
And note (a) if yours is a short, 20" BC bed CVA (a mk1 rather than a 1A) the travelling steady is very different. (b) if, like Dave S, you have a DRO scale here, the steady probably won't fit, without surgery! Hope this helps. Martin. |
