ML7 tooling
Will Scriven13/10/2020 11:53:07
5 forum posts
What was the intended original size tools which were to be used with the standard tool post on a myford ml7?
Neil Wyatt13/10/2020 13:24:02
19226 forum posts
749 photos
86 articles
I think the distance from the top of the cross slide to centre height is about 3/4" so the standard arrangement of a simple clamp could hold monster size tools.
Clearly it was never anticipated to use 3/4" tools clamped directly to the cross slide, but to use holders or packing with smaller tools.
Most people use an aftermarket toolpost to takes 8-10mm (5/16" - 3/8" tools.
Bazyle13/10/2020 13:52:16
6956 forum posts
229 photos
1/4 in Nobody could afford to buy big lumps that are 90% ground away. The large capacity of the holder is for holding other tool mounts not so you have to get big lumps of tool steel. Use packing, it is normally free.
Don't come back with the crap about tool ridgidity - if it is a problem you are takeing too big a cut.
Will Scriven13/10/2020 13:52:36
5 forum posts
many thanks Neil i'll take a look at some 3/8" ones I've just found.
ega13/10/2020 14:07:37
2805 forum posts
219 photos
Posted by Neil Wyatt on 13/10/2020 13:24:02:
I'm fairly sure it was 5/8".
KWIL13/10/2020 14:11:53
3681 forum posts
70 photos
If you look at the Myford supplied tools at that period you will find that the Myford range included a boat with a curved upper face which allowed height setting without shims, albeit with changing clearance angles.
Edited By KWIL on 13/10/2020 14:12:15
BC Prof13/10/2020 15:46:51
182 forum posts
The size of the Myford tooling as fitted to the "Boat" is 1/2".. When fitted horizontally in the "Boat" the distance from the base of the Boat to the top of the tool is 23/32" . Hope that this helps although I used 1/4 " blanks when I has an ML7
Swarf, Mostly!13/10/2020 16:04:10
753 forum posts
80 photos
I hope this helps:
The uppermost item is the four-way tool-post.
Best regards,
Swarf, Mostly!
Edited By Swarf, Mostly! on 13/10/2020 16:05:32
