ET Westbury Seal engine drawing error?
Cylinder and crank centreline not aligned
Willem Kotze12/10/2020 21:17:46
17 forum posts
I have taken on the building of a SEAL engine from castings procured some 50 years ago by a late friend. His son would like to have the engine to be completed in memory of his father. I have the old Model Engineer copy and could not understand the offset cylinder centreline to the crankshaft centreline. I have now received a new set of drawings still showing this offset of 1/8".
On checking the casting it would appear as if there is sufficient material available for the skimming of the manifold port side to get the cylinders on the crankshaft centreline. The cam-, idler- and crankshaft gear centres would have to be verified.
Comments on the above and overall build of the SEAL will be appreciated.
Neil A12/10/2020 22:11:50
160 forum posts
Offsetting the cylinder centreline to the crankshaft was a design feature of older engines, it was used to reduce the side thrust on the piston on the firing stroke. I think it was offset in the direction of rotation, but I would have to check. Someone will probably remember which side it is. You rarely see it done on modern designs.
Clive Hartland12/10/2020 22:14:56
2929 forum posts
41 photos
It is called, 'Desaxe' French I believe from older times. Neil describes the function correctly.
Neil A12/10/2020 23:10:47
160 forum posts
Thanks Clive, I could not remember what it was called.
Also I stand corrected on my statement about modern designs, from the internet, I find that it is in common use for automotive and smaller engines. I just had not seen it on newer large Diesel engines, I'll probably be corrected on that as well!
Willem Kotze13/10/2020 06:07:06
17 forum posts
Thanks gentlemen for the responses. I have seen the references to the offset on steam engines for easier starting, but never expected it on the IC engines.
If this is indeed a design feature I will stick to it.
JasonB13/10/2020 06:59:40
Willem, you may want to take a look at this thread where a couple of other issues are raised such as the pistons poking above the cylinder head.
One of the hit and miss engines that I made also had the offset crankshaft to cylinder which was a feature of the full size version.
Willem Kotze13/10/2020 20:22:12
17 forum posts
Jason, thanks for the link. Much appreciated.
Willie
