Studding
Tooling or parts
Brian jankovic30/09/2020 18:13:04
2 forum posts
hi, i am on the lookout for some 1/32" 16tpi square thread left and right hand, if not then tooling so i can make them, is there anyone that maybe able to help. Many thanks. Brian
roy entwistle30/09/2020 19:32:05
1716 forum posts
At 1/32" dia. you are in the region of 16BA I doubt you'll get square threads at that size. I have known to be wrong
Roy
Brian Wood30/09/2020 19:37:23
2742 forum posts
39 photos
Brian,
I don't want to burst your bubble, but that diameter, 1/32 inch, will not be able to contain a square form 16 TPI thread, there will be no metal left .
Sorry
Brian (another)
Edited By Brian Wood on 30/09/2020 19:37:50
Tony Pratt 130/09/2020 20:00:51
2319 forum posts
13 photos
Hi Brian J,
What's this for?
Tony
old mart30/09/2020 21:08:23
4655 forum posts
304 photos
More like 60tpi than 16.
Brian jankovic30/09/2020 21:09:53
2 forum posts
Hi all, sorry the diameter is 1/4" the tpi is 16, it is being used on an Britannia locomotive
Brian H30/09/2020 22:24:03
2312 forum posts
112 photos
Hello Brian (what a good name you have), I once needed to make a length of 1/4" X 16 tpi 2 start for the steering on a Clayton Steam Waggon. I made it out of silver steel, slightly longer that needed and made the end into a tap, hardened and tempered and cut off after being used to tap the bronze nut.
JasonB01/10/2020 07:00:19
Similar here when I needed it for the Fowler brake screw, I just ground up a 1/32" wide tool and screw cut it on the lathe and while the tool was in place cut another from silversteel which was then made into a tap. If I did it again I would make the tap longer.
