JonBerk | 28/08/2020 18:15:27 |
22 forum posts 2 photos | The majority of my lathe tools are HSS so I don't have much experience with inserts. I do have two inserts which are in the photo below, mostly used on aluminium. As can be seen, they are damaged and I would like to replace them. The only problem is I can't identify them from among all the illustrations on the web. I would be grateful if somebody could identify them and also confirm that they are suitable for turning aluminium and free cutting steel. Thanks Jon
Dave Halford | 28/08/2020 19:15:00 |
2536 forum posts 24 photos | SUMITOMO (maybe) TPGT 0802 or 0902 or 1103 depending on the unchipped length and thickness Available from the usual place. Not cheap |
John Hinkley | 28/08/2020 19:16:21 |
![]() 1545 forum posts 484 photos | JonBerk, I would venture to suggest that they are TNMG inserts. Possibly TCMG110404. You are best placed to measure the thickness and estimate or measure the rake and corner radius and apply the results to the following table: Good luck! John Edit: I see I've been beaten to it - with a different result! I use polished inserts for aluminium and "Standard" ones for steel.
Edited By John Hinkley on 28/08/2020 19:17:54 |
Martin W | 28/08/2020 19:30:41 |
940 forum posts 30 photos | Jon I have not seen the like of these either. However they look to have similar dimensions to the TCMT1102nn series of inserts. If it would help I could send you a sample insert that is designed for aluminium, tip definition - Aluminum Carbide Insert TCGT110204-AK--, to see if it would fit the insert bit bar that you have. While these inserts are designed for aluminium they will work on free cutting steels provided that one isn't too enthusiastic with the depth of cut or feed rate. If your interested then contact me via the PM system on this site and I will get one in the post. Cheers Martin |
JasonB | 28/08/2020 19:39:10 |
![]() 25215 forum posts 3105 photos 1 articles | A = TBGT L and B = TBGT R as the chipbreaker is only on one side of each corner they are handed inserts, the B in the code may differ as can't see the angle from the photos. Having said that if you just wanthem for aluminium then the common TCGT 110204 would be fine for general use.
Edited By JasonB on 28/08/2020 19:40:14 |
JonBerk | 31/08/2020 19:39:57 |
22 forum posts 2 photos | Thanks fot the information and the offer from Martin.. Having looked at the prices for some of these inserts and the fact I have enough HSS to outlast me, I think I'll continue to use HSS tools. Thanks again Jon
old mart | 31/08/2020 21:15:51 |
4655 forum posts 304 photos | As far as I can tell from the pictures and assuming they are single sided with sloping, not square edges, they are likely to be TCMT 09 for steel, and TCGT 09 for aluminium/ finishing stainless and steel. There doesn't seem to be an 08 size and the next one down may be 06 which is much too small. The size is the inscribed circle diameter which will fit in the triangle. These left and right handed inserts are rare nowerdays, you will be unlikely to get any. For most applications, the symetrical type which is common today is better anyway. Prices vary from silly overpriced big brands to the affordable Chinese ones which are very good. |
