epoxy resin preventing from sticking.
speelwerk14/08/2020 21:45:55
464 forum posts
Would a silicone spray prevent a metal (silver) hinge from sticking to a casting epoxy resin, or should I use something else? Niko.
Brian Sweeting14/08/2020 22:03:05
453 forum posts
There are a few things available..
Read here...
Non stick epoxy
Jeff Dayman14/08/2020 23:58:48
2356 forum posts
47 photos
Silicone may interfere wit the curing of the epoxy. Paraffin wax (solid at room temperature) as used for candles and home canning can be used as a "mould release" coating, and will not interfere with the epoxy cure, or bleed out of the hinge later!
If you melt some wax in a tin over a pan of hot water and dip / air cool the hinge twice you will get a thin but complete coating. Good luck with it!
Old School15/08/2020 06:23:54
426 forum posts
40 photos
PVA mould release just paint on a couple of coats.
Joseph Noci 115/08/2020 07:27:11
1323 forum posts
1431 photos
Posted by Old School on 15/08/2020 06:23:54:
Second that - works a treat - just comes in inconveniently large quantities ( 25liters) in my part of the world!
Any carnauba based wax works very well - used as epoxy lamination release on molds the world over..wipe it on, let it almost dry and buff it a bit - do a second coat and thats it.
If you can get hold of Meguiars Mirror Glaze wax - that would be perfect.
Joe
Brian Oldford15/08/2020 08:10:44
686 forum posts
18 photos
*1 for Meguiars Mirror Glaze 8 mould release. Great stuff!
Clive Brown 115/08/2020 08:46:32
1050 forum posts
56 photos
Where suitable,I've used brown parcel tape, the very thin stuff, as "non-stick" for resins. Works well, one big advantage being that there's usually a roll of it conveniently available in the house.
speelwerk15/08/2020 10:01:45
464 forum posts
Thanks all! Lots of possibilities, I like the paraffin one. Niko.
Edited By speelwerk on 15/08/2020 10:02:26
Jager15/08/2020 13:37:46
44 forum posts
5 photos
I use DEVCON for bedding rifle actions into stocks. In order to ensure that I can get the two items apart after curing I first wipe the barreled action down with alcohol then brush all over with boot polish, leave 5 mins to harden, polish off and repeat. Never had a problem seperating two very expensive items.
