Hardened Steel
ALAN HEATH | 27/07/2020 17:44:18 |
9 forum posts | I bought a couple of pieces of steel to work on not realising they were hardened steel ,I have a Myford Ml7 any advice on what type of tool ? would be great |
Andrew Tinsley | 27/07/2020 17:57:15 |
1817 forum posts 2 photos | If the steel is really hardened carbon steel, then you could soften it by simply heating with a propane torch until it is red hot. Soak it at temperature for a few minutes and let it cool naturally. Otherwise you are looking at carbide tooling. If you don't know what grade of steel it is, then you are quite likely to have something that is a tough steel alloy, if so then carbide tooling is required. Andrew. |
ALAN HEATH | 27/07/2020 18:08:29 |
9 forum posts | Thanks Andrew, I have a propane touch will give it a go .
Martin Kyte | 27/07/2020 18:15:26 |
![]() 3445 forum posts 62 photos | Start again with the correct material. Put what you have aside until you need some hardened steel. Life is too short for messing about. regards Martin |
Kiwi Bloke | 28/07/2020 07:27:39 |
912 forum posts 3 photos | As above - avoid the problem - however various carbides, ceramics or Stellite will do the job. Not sure that a ML7 would have the rigidity, speed or grunt though, depending on job dimensions, of course. |
John Haine | 28/07/2020 07:33:22 |
5563 forum posts 322 photos | "Hardened" steel could be silver steel, possibly hardened, or high speed steel. Which is it? |
Hopper | 28/07/2020 08:19:57 |
![]() 7881 forum posts 397 photos | It's best to buy mild steel of known provenance for these lightweight hobby lathes like the Myford etc etc. Hardened and alloy steels etc can be a bit too much for them and cause much heartache in the form of poor finish and worn and broken tooling. |
Baz | 28/07/2020 08:56:52 |
1033 forum posts 2 photos | Totally agree with Hopper, buy from a reputable source. Myford lathes just don’t have the rigidity and power to deal with hardened or alloy steels, neither do any of the similar sized Chinese offerings for that matter. |
ALAN HEATH | 28/07/2020 09:11:50 |
9 forum posts |
SillyOldDuffer | 28/07/2020 10:59:59 |
10668 forum posts 2415 photos | Posted by ALAN HEATH on 28/07/2020 09:11:50:
I wasted several months struggling to turn various bits of scrap and DIY store metal I'd collected randomly. Eventually, I got hold of some EN1A (one of mild-steels), and was amazed how well it cut. I was unlucky because all my scrap metal was horrible. I'd assumed a metal-lathe would happily cut any metal it was given: not so - many metals don't machine well. For example:
Bottom line on metals is they're engineered for a purpose, often not suitable for home workshops. Nowadays, I prefer to buy metal where machinablilty is mentioned positively in the description. Words like 'free-cutting'. If you have a local metal supplier, tell the man you want to machine it. With experience it gets easier to cope with random scrap. I recommend beginners avoid unknown metals, because they can't tell if the problem is the operator, the machine, the cutter, or the material. Best to eliminate the material as a problem. In practice, I find scrap more trouble than it's worth. Some lucky chaps have no scrap problems. I think it's down to were they live! In a manufacturing area suitable off-cuts are likely. Out in the sticks, probably not. The easy answer is to buy known materials. Dave
ALAN HEATH | 28/07/2020 11:44:19 |
9 forum posts | Thanks Dave, I take on board what you said, I am just starting out I have no prior knowledge of lathes or metal. I have learnt a lot from the internet, I love being in my workshop I guess it is the basics that I lack But as long as I progress I am happy and thanks again ,its people like yourself keeps me going. All the very best Alan |
Dusty | 28/07/2020 12:19:28 |
498 forum posts 9 photos | I know it might seem a stupid comment, but how do you know it is hardened? where did you purchase the steel from? I ask these questions because it might possibly be your technique that is the problem, in view of your limited experience. It is most unusual to purchase hardened steel except from specialist stockholders. Was this a purchase from a well known internet auction site? |
Martin Kyte | 28/07/2020 13:02:40 |
![]() 3445 forum posts 62 photos | Hi Alan As you are just starting out do buy free machining material. You will generate enough problems yourself without buying in more. If you are looking for some starter projects you could do worse than a couple of the Hemmingway kits especially if you find something like a workshop tool or gadget that you would find particularly usefull. The advantage is you get all the materials supplied plus drawings and notes. They make very good learning projects and you end up with something usefull at the the end. regards Martin |
Howard Lewis | 28/07/2020 20:43:16 |
7227 forum posts 21 photos | If you MUST turn hardened steel, you need to use a carbide tipped tool, and run at high speed with a small depth of cut and feed, on a Myford. I used this technique to turn down some spacers for a horizontal milling arbor. The swarf coming off as red hot wire was quite entertaining! But don't thrash the machine with hard material unless you have to. Howard |
Sam Stones | 28/07/2020 23:59:13 |
![]() 922 forum posts 332 photos | Allan, In addition to the excellent information above, I feel sure that, besides noting how a piece of metal responds when rubbed with a file you’ll begin to notice, when grinding a piece of steel, how the sparks vary one type of steel to another. I couldn't find one, but someone here will now step forward with links to show where this was a forum topic. While this next bit is somewhat over the top, it might be useful in the future … Some basic questions … Does the steel resist filing and by how much, and are the sparks dull with few or no ‘feathers’ or bright and sparkling? A classic ‘spark’ comparison would be that between a high speed steel (HSS) tool bit, and another common workshop material, silver steel. The former showing dull red sparks with few feathery bursts, while the (high carbon) silver steel sparkles with lots of feathery bursts. Have fun, Sam |
ALAN HEATH | 29/07/2020 08:14:43 |
9 forum posts | Thanks for the info Sam. |
