Vic | 17/07/2020 16:25:02 |
3453 forum posts 23 photos | I have a small carbide bull nose mill and just noticing it in my box it’s got aluminium alloy swarf “welded” to it. Is there an easy way of removing it? |
old mart | 17/07/2020 16:33:58 |
4655 forum posts 304 photos | Just use sodium hydroxide (lye, caustic soda) solution, about 10% WV. An easy source is drain unblocker. It also works with steel cutters including blocked hand files. You should use a little lubricant when cutting aluminium, WD40 or AC90, or paraffin/kerosine if you like smelly work. Edited By old mart on 17/07/2020 16:34:43 |
Mike Poole | 17/07/2020 17:23:39 |
![]() 3676 forum posts 82 photos | Picking it off could chip the edge, chemical stripping is safer. Mike |
Vic | 18/07/2020 09:48:38 |
3453 forum posts 23 photos | Thanks, I’ll try the caustic soda. |
Tim Stevens | 18/07/2020 18:22:15 |
![]() 1779 forum posts 1 photos | Washing soda - sodium carbonate - is kinder to the hands, and anything else in the, er, kitchen. It is not quite so quick, but much cheaper, easier to find in the shops, and will not go off in storage. In fact, caustic soda will slowly turn to washing soda unless it is stored in a properly sealed container. Might help someone - Tim |
Vic | 18/07/2020 19:22:54 |
3453 forum posts 23 photos | Thanks Tim. |
Mark Rand | 19/07/2020 01:02:01 |
1505 forum posts 56 photos | If you use Washing soda, heat it up. It is pretty slow at room temperature, but works quite quickly close to boiling point. The aluminium carbonate that results is insoluble and the reaction will stop if all the washing soda gets used up. |
