Is this a plug tap
AdrianR17/07/2020 14:00:44
613 forum posts
39 photos
Hi,
I need to tap an M3 thread for 4.5mm in a 5.5mm deep hole. For this I thought I would need a plug tap, So I bought one, and I was surprised that it has a point at the end.
I was expecting a plug tap to have a square end. When buying it I had a choice of taper, second and plug, to me this looks like second. Am I wrong in expecting a square end?
Thanks
Adrian
Chris Evans 617/07/2020 14:08:09
2156 forum posts
Lots of plug taps around now in that style. I just grind the point off.
geoff adams17/07/2020 14:29:11
214 forum posts
207 photos
plus one grind it flat
Andrew Johnston17/07/2020 14:40:18
7061 forum posts
719 photos
Looks almost like a 2nd tap to me. You'd be better off using a spiral flute tap.
JasonB17/07/2020 14:51:16
Even then you may still want to grind the point off depending one what make the Spiral Flute taps is.
HOWARDT17/07/2020 15:50:56
1081 forum posts
39 photos
Taps can have external or internal centres. The plug, second and taper taps each have a different number of threads in the taper. Even a plug tap has a lead but may be only a couple of thread pitches. Machine taps are different to hand taps. For full description have a look at someone like Emuge, they make taps including specials. The variation in lead from one manufacturer to another can be quite a lot as some ere on the short side others on the long. As has been said modify what you have to suit to get maximum depth, but use the taper and second first otherwise you may break the tap.
AdrianR17/07/2020 16:35:46
613 forum posts
39 photos
Well, just to add to the confusion, our transatlantic cousins apparently call second taps plug and plug taps bottoming. I wonder how many plug taps we buy are really second taps.
Of to the grinder I go.
Adrian
Howard Lewis17/07/2020 16:49:43
7227 forum posts
21 photos
Recently, needing a thread in a very short, blind hole, I ground the end of a 5 x 0.5 mm plug tap back until it was flat.
The ends will be pointed for the purpose of making the Tap, and the leading end will have little purpose for most of our uses.. Pointed ends tend be on the smaller Taps, with centres on the larger, where there is metal to accommodate a centre drilling.
If the other end is pointed, rather than centre drilled, it can be used with a female centre to hold the Tap vertical to the job.
peter smith 519/07/2020 22:26:50
93 forum posts
Many moons ago I was demonstrating how to tap a hole. 1/4” BSF, no 4 drill with the ” half a turn forward. Half a turn back. Hal’s turn forward etc. The class started giggling quick check of zip the tap was twisting!!! It had not been hardened. Manufactured in north London they sent me a dozen in recommence.
they don’t make em like that any more!!!
Danny M2Z20/07/2020 06:44:26
963 forum posts
I have set of Sutton Tools (Australian) B.A. taps. Each size came in taper, intermediate and plug sizes. The plug (2 black stripes) have a square cut end with a minute tapered section.
What I did find interesting is that the diameter of the threaded sections gradually increases from the tapered to the plug version so that when changing from taper to intermediate the tap will cut the previous thread a bit deeper.
Quite useful if one is tapping a 'tight' thread such as for a model diesl engine compression screw.
For tapping a blind bottomed hole the pointy ones look a bit useless.
* Danny M *
JasonB20/07/2020 07:07:27
Danny, you have what are known as "sequential taps" hence the diameter difference and the marking rings.
