Camshaft
SteveW23/06/2020 16:42:39
140 forum posts
11 photos
Camshaft and timing gear from a 120cc 4 stroke. I’ve not seen this in an engine before. What chance of a 3D print of something like it for a model?
picture in album
Edited By SteveW on 23/06/2020 16:45:21
Kiwi Bloke24/06/2020 10:02:11
912 forum posts
Good grief! Either it's the result of some pretty fancy materials development, or it's been designed to fail just outside its warranty period. I suspect the latter...
not done it yet24/06/2020 11:22:12
7517 forum posts
20 photos
Does it have lightweight plastic valves and piston? 🙂
Hopper24/06/2020 11:36:26
7881 forum posts
397 photos
There's some fine engineering coming out of China these days. Obviously it does the job. Roller tappets or flat tappets, in steel or matching plastic? And side valve so valve train weight and spring pressure is low?
I guess the average lawnmower runs one hour a week for half the year so about 125 hours over 5 years. Probably last that long . Then you buy a new one.
Jeff Dayman24/06/2020 12:14:17
2356 forum posts
47 photos
Briggs and Stratton have had plastic gears and cams in their high volume production engines for at least 18 years. I had one such engine on my mower for 17 years, used 2 1/2 hr per week about 6 mo of the year. Never had a minute's trouble with that engine's internals, and it was running perfectly when I sold it. Last year I had an identical one 18 years old cross my workbench with extreme cylinder and valve guide wear, from running in a sandy area without an air filter for several years. During strip down I noticed that there was no visible wear at all on the plastic cams or gear, they looked just like the day they were made.
Intuitively after years working in the plastics / tooling side of industry I would say plastic was not a good choice for engine gears and cams but it obviously works when engineered for the loads and temperatures it sees with the right type of plastic, the right lubrication, etc. Nothing wrong with it if done correctly, in my opinion.
Martin Connelly24/06/2020 12:29:48
2549 forum posts
235 photos
I've got a Briggs and Stratton engine on my mower and I don't know how old it is but 20 years is probably the minimum. The engine still runs fine (it did have a new rubber gasket/joint/functional valve part for the carb a few years ago) but the sheet metal of the body has rusted through at least one place and the wheels are looking as though they are not going to last much longer.
Martin C
Hopper24/06/2020 12:37:46
7881 forum posts
397 photos
Posted by not done it yet on 24/06/2020 11:22:12:
Ford built an all plastic car engine some years ago but never went into production.
Neil Wyatt24/06/2020 12:54:04
19226 forum posts
749 photos
86 articles
My next Ed's Bench (already written) will feature a 3D printed differential for an RC car, not the same thing but I'm continualy discovering new practical applications for 3D prints.
SteveW25/06/2020 11:06:15
140 forum posts
11 photos
Followers were flat and highly polished with lightweight pushrods. No signs of wear. The internals of the engine were quite high quality.
if something like it was available for a model size engine it would encourage me to have a go and I guess ,like most other model engineers, I’d be happy if it ran for 15 minutes every now and again.
Steve
Hopper25/06/2020 11:30:54
7881 forum posts
397 photos
It certainly would be interesting. I think it would have to be some pretty special plastic to withstand the rigours and the temperatures. Not sure if that would be available for 3D printing yet???
Jeff Dayman25/06/2020 12:15:10
2356 forum posts
47 photos
As far as I know, nobody yet offers a 3D printer and filament to make hi temp nylon alloys, polyphenylene sulfide, or polysulfone plastics. These are the big three candidate plastics for high heat high load applications. I think the pistons in the Ford plastic engine mentioned in an earlier post were polyphenylene sulfide with a ceramic insert on the hot side.
These plastics are available in rod and block form for machining parts out of, but they are expensive. Boedeker in USA is one supplier.
Stratasys in the USA is making 3D prints in Ultem polyetherimide, and has done for years, these are good to 200 deg C service. I just ordered some printed guard boxes for hot electrical components for a client in this material last week.
The major problem with plastics for engine cyls and pistons and valves is that they don't conduct heat well and they have high friction when running against each other.
A steel wet liner in a PPS block though, and a PS piston with PTFE faced ceramic side slippers and a ceramic top insert......maybe........
