Rob Divall | 21/06/2020 17:19:08 |
5 forum posts | I raised a query a couple of weeks ago because my saw would not cut straight - kept veering off to one side. In all I received 10 replies from members of this forum, with loads of help, and I have been able to completely re-set the machine, such that it now works PERFECTLY. I am so pleased, so thankyou to all you chaps who have helped me out. One bit of help suggested "Tuff Saws" as a blade supplier. I have just fitted one and am delighted with the standard of cutting I now achieve - again, thankyou all for this tip. |
Howard Lewis | 21/06/2020 18:13:16 |
7227 forum posts 21 photos | Am pleased that you have now got the machine sorted.. Very often, it is the careful adjustment that turns a sow's ear into a close approximation to a silk purse.. It used to be said that the late Freddy Dixon (Who many years ago, raced Rileys, ) could increase the top speed of a car by 5 mph just by stripping and rebuilding the rear axle. Thank You for letting us know that you have been able to achieve success. Howard |
Rob Divall | 01/07/2020 18:16:06 |
5 forum posts | I have been using my rejuvenated bandsaw. Works beautifully! Today been cutting discs from a 65mm dia piece of cast iron. Cuts with what looks like finely machined surface. But I wonder whether I should back off the saw blade tension between jobs - sometimes it will be a week or two between operations. Any advice on reducing tension during "resting time"?
Rob |
Emgee | 01/07/2020 18:27:37 |
2610 forum posts 312 photos | I believe Tuff Saws packaging includes a tip to slacken off tension when not in use, if you do slacken off make yourself a label to hang on the saw to remind you to tighten the blade before use, or like me you will be refitting the blade. Emgee |
ega | 01/07/2020 18:42:59 |
2805 forum posts 219 photos | I always slacken off by one complete turn of the screw after use and switching off at the mains socket; next time of use I am reminded of the need to re-tension by having to switch on again. |
martin perman | 01/07/2020 18:58:46 |
![]() 2095 forum posts 75 photos | Just to buck the trend once fitted I dont release the tension on my bandsaw blades and I can go weeks between cutting jobs. I use a local saw doctor to me and they make my blades with no issues. Martin P
