Lee Rogers | 17/06/2020 14:11:22 |
![]() 203 forum posts | I'm looking to replace a wheel on my bench grinder. Will a white wheel be ok for HSS lathe tools and carbide end mills and slot drills? I'm seeking the best compromise as like many of you I have to get the most out of what I have. |
Clive Brown 1 | 17/06/2020 14:30:52 |
1050 forum posts 56 photos | I replaced the grey wheel on my bench grinder with a white wheel, both 60 grit. Can't recall the bond grades. TBH there doesn't seem great difference. If anything the white wheel is softer and doesn't seem to heat a HSS tool so much so I suppose that will be my slight preference. It needs dressing more often. Edit, just noticedyour reference to carbide. A white wheel is definitely unsuitable, green is needed. Edited By Clive Brown 1 on 17/06/2020 14:33:27 |
Thor 🇳🇴 | 17/06/2020 17:24:22 |
![]() 1766 forum posts 46 photos | Hi Lee, I use a white grinding wheel on my bench grinder for grinding HSS tools, this works well. For grinding carbide slot drills I use a diamond wheel in my home made Tool & Cutter Grinder, for me that worked better than a green wheel. Thor |
Lee Rogers | 17/06/2020 17:30:54 |
![]() 203 forum posts | Sounds like the white wheel and a diamond wheel may be the route to take.
ega | 17/06/2020 23:06:34 |
2805 forum posts 219 photos | Thor may be running his diamond wheel at a slower, more suitable speed, than that of a typical high speed bench grinder. |
Lee Rogers | 18/06/2020 06:39:11 |
![]() 203 forum posts | Thanks ega .I'll take a look at the fpm numbers and see if it's possible to run a smaller diameter diamond wheel to achieve the correct speed. |
Bo'sun | 18/06/2020 09:26:02 |
754 forum posts 2 photos | Hi, Don't forget, a smaller diameter wheel will result in a more concaved profile on your cutting tools. |
AdrianR | 18/06/2020 09:34:29 |
613 forum posts 39 photos | What about a CBN wheel, wouldn't that be able to grind HSS and TC? Adrian |
RobCox | 18/06/2020 09:45:19 |
82 forum posts 44 photos | CBN will grind both HSS and carbide OK. I use a coarse grey wheel on one side of my bench grinder for rough shaping HSS before giving it a final polish on the CBN wheel. The CBN wheel is too slow for roughing, as it's a fine grain - I think. I originally got it for woodturning tools, but it's great for lathe toolbits. Rob |
ega | 18/06/2020 10:42:31 |
2805 forum posts 219 photos | Posted by Bo'sun on 18/06/2020 09:26:02:
Hi, Don't forget, a smaller diameter wheel will result in a more concaved profile on your cutting tools. True, but you could consider fitting a depressed centre wheel intended for grinding on its side. Incidentally, I have found a Tyrolit A220 CBN dressing stick useful for dressing resin-bonded wheels. |
