Die ing to know
Steve King 506/06/2020 17:44:49
86 forum posts
95 photos
Good evening
I have a chart that tells me what drill size i need to drill for tapping.
Was wondering if there was a chart that give what OD i need to turn on the lathe to cut treads with a die?
M10 1.25 is the thread i want to cut.
I do have the 20th edition engineers book and was looking through it today but there is that much information in it i got lost. Also i have to read it in the shed as the wife doesn't want it in the house because it stinks of must lol.
Thanks
Steve
David Noble06/06/2020 17:46:48
402 forum posts
37 photos
Hello Steve,
O.D. is always the same as the thread size i.e. M10 is 10mm O.D.
You will find that after running a die along it, the O.D. will be slightly smaller
David
Edited By David Noble on 06/06/2020 17:50:40
Edited By David Noble on 06/06/2020 17:51:14
pgk pgk06/06/2020 17:50:55
2661 forum posts
294 photos
m10 is 10mm but there is a tolerance range Link
pgk
Tony Pratt 106/06/2020 17:59:37
2319 forum posts
13 photos
I tend to turn the OD slightly less than nominal, makes no difference to functionality but it cuts easiersmiley Just used a die for an M6, turned to 5.95 diameter but 5.9 would have been fine.
Tony
Howard Lewis06/06/2020 18:19:34
7227 forum posts
21 photos
Turning the raw material slightly undersize before using a die results in a truncated thread.
Truncated threads are not unusual, and are intended to prevent root/crest interference.
Back in the late 50s there were formulae to calculate how much undersize the raw material should be, to truncate Unified threads.
In the same way that using a slightly oversize drill for tapping a hole, and reducing % engagement, does not reduce thread strength disastrously, neither does truncating a male thread.
JA06/06/2020 18:24:30
1605 forum posts
83 photos
I cannot cut an M10 with a die, either holding the work in a vice or lathe chuck. I would not entertain doing the job under power. I would use the die as a chaser after cutting most of the thread with a single point tool.
I finished a 7/16”BSF thread in brass this way two hours ago.
JA
Howard Lewis06/06/2020 20:19:21
7227 forum posts
21 photos
You can always Tap or Die threads in the lathe, without being under power.
Make and use a Mandrel Handle.
1 ) You can feel how much torque is being applied, so hopefully, can stop before breaking anything, if there is a jam up.
2 ) If cutting a thread upto a shoulder, you can stop just before hitting the shoulder, avoiding broken tooling or a ruined thread.
Ideally, a Die should be held in a sliding Tailstock Die Holder.
This should hold the Die square to the work, avoiding drunken threads, also the risk of stripping the just cut thread by trying to drag the Tailstock along the lathe bed.
For the same reasons, it is worth making up a sliding Tap holder for the Tailstock. Mine uses ER 25 collets.
The Tap will slip in the holder rather than breaking, if anything gets even remotely tight.
Steve King 507/06/2020 14:13:45
86 forum posts
95 photos
Thanks for all the replies guys iv taken your advice onboard.
See link for the build
https://www.model-engineer.co.uk/forums/postings.asp?th=165635
Thanks
Steve
