lfoggy | 01/06/2020 14:30:08 |
![]() 231 forum posts 5 photos | I'm currently building the Quorn Mk3 and am working on the spindle assembly. The threaded end caps to the spindle assembly incorporate an annular groove as part of the labyrinth seals, machined into the face of the caps, that is 1.6mm wide, 4.9mm deep. I've never machined anything quite like this before. What's the best way to achieve this ? To machine it on the lathe would require a special cutter with considerable clearance which I think would be quite fragile.I am thinking of maybe milling it with a slot mill on the rotary table.... |
Martin Connelly | 01/06/2020 16:00:30 |
![]() 2549 forum posts 235 photos | A nice stiff bar with a bit of HSS ground to suit and clamped in it will cut these quite easily. To cut it on a milling machine and RT would require a small Woodruff key cutter if you can get one that small or are willing to grind one down. An internal grooving tool will probably be something you can use for future jobs. Martin C |
lfoggy | 01/06/2020 16:05:12 |
![]() 231 forum posts 5 photos | I don't follow you there Martin. The groove is on the face of the part, not in the bore. There are some grooves in the bore as well which are easy.... |
Martin Connelly | 01/06/2020 16:11:12 |
![]() 2549 forum posts 235 photos | Sorry, thought you were talking about the internal grooves. The external ones require a trepanning tool. Should be plenty of references in the forum or the internet. Martin C Thread on grinding a trepanning tool Link added Edited By Martin Connelly on 01/06/2020 16:15:01 |
JasonB | 01/06/2020 16:17:33 |
![]() 25215 forum posts 3105 photos 1 articles | You could also make a tool like a hole saw out of Silver steel, turn to 20.6mm and bore to 23.9 adding a tiny amount of relief if needed by setting the topslide over a degree or two. Then cut some teeth in the end, I would just have a few so you can get a good gullet to clear swarf. |
lfoggy | 01/06/2020 16:28:40 |
![]() 231 forum posts 5 photos | Posted by Martin Connelly on 01/06/2020 16:11:12:
Sorry, thought you were talking about the internal grooves. The external ones require a trepanning tool. Should be plenty of references in the forum or the internet. Martin C Thread on grinding a trepanning tool Link added Edited By Martin Connelly on 01/06/2020 16:15:01 The groove is 1.65mm wide and 4.9mm deep. Is a face trepanning tool really going to work do you think? The tool would be very fragile. |
ega | 01/06/2020 16:29:26 |
2805 forum posts 219 photos | Unless the design has been changed this is well covered in the book. I could post a photo of the cutters I made for the job if this would help. |
lfoggy | 01/06/2020 16:30:11 |
![]() 231 forum posts 5 photos | Posted by JasonB on 01/06/2020 16:17:33:
You could also make a tool like a hole saw out of Silver steel, turn to 20.6mm and bore to 23.9 adding a tiny amount of relief if needed by setting the topslide over a degree or two. Then cut some teeth in the end, I would just have a few so you can get a good gullet to clear swarf. I like that idea. |
lfoggy | 01/06/2020 16:31:39 |
![]() 231 forum posts 5 photos | Posted by ega on 01/06/2020 16:29:26:
Unless the design has been changed this is well covered in the book. I could post a photo of the cutters I made for the job if this would help. I don't have the book, just the drawings! Yes, pics of your cutters would be great. |
Martin Connelly | 01/06/2020 16:43:19 |
![]() 2549 forum posts 235 photos | 25mm Rotabroach mini cutter. 20.5mm internal diameter, depth of cut 6.3mm max. Could be ground to required dimensions if you had one. This is the sort of cutter Jason is suggesting, OD and bore not as Jason suggested Martin C Edited By Martin Connelly on 01/06/2020 16:48:12 |
JasonB | 01/06/2020 17:00:09 |
![]() 25215 forum posts 3105 photos 1 articles | I put it down to bad dimensioning of drawing |
Clive Brown 1 | 01/06/2020 17:07:31 |
1050 forum posts 56 photos | The Mk I, whch I built more years ago than I care to remmber,has the same feature. Although Prof. Chaddock covers the machining of the spindle at some length in the ME articles, he doesn't mention this groove. Presumably run of the mill, (pardon the possible pun!), to him. I can't remember my method, it certainly wasn't a trepanning tool. Most probably a silver-steel lathe tool, used with trepidation.
ega | 01/06/2020 17:14:12 |
2805 forum posts 219 photos | I see that the MK3 drawings are metric; DHC's design was, of course, imperial and he specified a (double-ended) cutter with one end 0.940" OD x 0.810 ID, the other 0.815" x 0.685"; I opted to make two cutters which seemed easier: IIRC, I marked the teeth out in the lathe and filed them by hand with a neutral front rake. I think the through hole was to facilitate holding the tool for hardening and tempering. |
ega | 01/06/2020 17:23:36 |
2805 forum posts 219 photos | Posted by Clive Brown 1 on 01/06/2020 17:07:31:
... Although Prof. Chaddock covers the machining of the spindle at some length in the ME articles, he doesn't mention this groove. ...
Surprising, as the book is very much the same as the ME articles; another good reason to stump up for the book! The OP just has the drawings; if they came from Hemingway without instructions it seems likely that they assumed either the articles or the book would be available. I realize that a competent machinist ought to be able to reproduce a part from a drawing bit I like to have a bit of help by way of instructions! |
Fatgadgi | 01/06/2020 17:56:10 |
188 forum posts 26 photos | Hi Ifoggy - the proper tool is a Face Grooving Tool. Try searching eBay and you will find them with inserts. It’s basically like a parting tool, but the sides are curved to fit the groove. Easy to grind from HSS blank, especially for one-offs Cheers - Will |
old mart | 01/06/2020 18:00:29 |
4655 forum posts 304 photos | I would cheat and use the mill and rotary table with a 1/16" end cutting tool. But I have the patience to go round and round for a very long time. I wonder how tight the tolerances are, or even if the piece could be made from two parts Loctited together? |
John P | 01/06/2020 18:38:12 |
451 forum posts 268 photos | Posted by lfoggy 01/06/2020 14:30:08 I'm currently building the Quorn Mk3 and am working on the spindle assembly.
Unfortunately this is one of the chicken and egg type moments when building I have just recently completed 3 off grinding spindles similar to the John |
lfoggy | 01/06/2020 19:19:47 |
![]() 231 forum posts 5 photos | Thank you everyone that is very helpful. I already have a Deckel SO clone grinder which is quite versatile so I am going to try and grind a suitable curved single-point face grooving tool and see how I get on with that. If that doesn't work I will make a cutter like ega's pictures. You may well ask why I am building a Quorn if I already have a decent tool and cutter grinder. I don't really have an answer to that.... |
