MC Black 2 | 30/05/2020 18:20:46 |
99 forum posts | I wonder if one or more of the wise subscribers can provide pointers about two things: Firstly, can anybody kindly suggest where I might purchased a 7.3mm HSS drill where the postage isn't three times the cost of the drill. It's for a particular job - creating a hole to tap for M8 x 1.0mm thread. Secondly, I'm buying various drill bits for different jobs and need an inexpensive empty 6.0mm to 10mm x 0.1mm box to keep them in. Any suggestions, please? Very many thanks for your anticipated assistance. MC Black
Martin Connelly | 30/05/2020 18:25:28 |
![]() 2549 forum posts 235 photos | Standard tapping drill for metric threads is size minus pitch. That gives 7mm for your thread, do you want to go up to 7.3mm for a reason because 7mm is probably easier to find. Your question regarding a box for drills has come up in the past. It is probably easier to make your own stand than to buy an empty box. You could buy a set, the drills in the set I have are good quality. If they break or wear or fail to drill what you want just replace the ones you use up with good quality ones as required. Martin C Edited By Martin Connelly on 30/05/2020 18:30:22 |
not done it yet | 30/05/2020 19:25:43 |
7517 forum posts 20 photos | HERE is one previous thread on this subject. Likely lots more. |
Former Member | 30/05/2020 19:30:22 |
[This posting has been removed] | |
larry phelan 1 | 31/05/2020 13:26:08 |
1346 forum posts 15 photos | You might also try Drills UK. I have bought from them several times and found them good to deal with. |
