Ian Parkin | 12/05/2020 16:59:55 |
![]() 1174 forum posts 303 photos | Not sure how to word this i have 10 shafts 20mm dia and 1200 long made of alloy and they had a strip of like cheese grater/lemon zester type material wound round the shaft in a spiral. this is the take up shaft on a printing press for a wash up roll which is like very strong kitchen roll..the operator winds the material round the shaft and the rough surface grabs the material and allows it to be rolled up on the discard roller. the zester type stuff had fallen off them all ive knurled a few of them to see if that works..with some success but the operators want it like original.... really grabby.. where could i get such strip material ?
Edited By Ian Parkin on 12/05/2020 17:00:27 |
Brian Sweeting | 12/05/2020 18:37:17 |
453 forum posts 1 photos | Not exactly cheese grater but try a Google search on "prikka strip", might be suitable. |
Ian Parkin | 12/05/2020 19:37:36 |
![]() 1174 forum posts 303 photos | Brian the prongs are too long for this application ill try and get a photo of one tommorow off the press. the zester type of strip is thin stainless with a grid of square punching from behind making little pyramids of sharp points which grab the roll |
Grindstone Cowboy | 12/05/2020 20:13:07 |
1160 forum posts 73 photos | Ian I know exactly what you mean, but I just can't remember where I've seen it. Which isn't much help, I realise, but it may come to me suddenly. Regards, Rob |
David Maynard 4 | 12/05/2020 20:51:21 |
15 forum posts 2 photos | We used to be able to get 'punchings strips' the waste after punching out bottle top blanks. If still available, would these work?
David |
roy entwistle | 12/05/2020 20:52:44 |
1716 forum posts | What press is it ? Could the manufacturer help ? |
HOWARDT | 12/05/2020 20:58:54 |
1081 forum posts 39 photos | Expanded or punched metal, still a few companies in the Uk. |
Dick H | 12/05/2020 21:37:21 |
141 forum posts 1 photos | Try "perforiertes Blech" or Lochblech. (perforated sheet). |
DiogenesII | 12/05/2020 21:47:19 |
859 forum posts 268 photos | Posted by Grindstone Cowboy on 12/05/2020 20:13:07:
Ian I know exactly what you mean, but I just can't remember where I've seen it. Which isn't much help, I realise, but it may come to me suddenly. Regards, Rob ..one used get given a bit to roughen the tube with in puncture repair kits.. Er, if anyone does an image search on terms similar to "perforated abrasive strip", please take care which web domains you click on, regardless of the image displayed.. ..it's lucky Mrs Diogenes has a sense of humour.. ..it might be best to omit the word "strip", possibly Edited By DiogenesII on 12/05/2020 21:49:06 |
Grindstone Cowboy | 12/05/2020 22:16:57 |
1160 forum posts 73 photos | Puncture repair kits! That's the place. You'd need quite a few to cover all those rollers The perforated strip I've found by Googling has nice round holes, but knocking a square punch through might raise the edges enough to provide the necessary grip. Pretty boring job though... Regards, Rob |
peak4 | 13/05/2020 01:54:10 |
![]() 2207 forum posts 210 photos | Ian, see P24 of this pdf UK contact details HERE Good luck, hope you're keeping well over there Bill |
Ian Parkin | 13/05/2020 15:06:33 |
![]() 1174 forum posts 303 photos | Here’s a pic of the roll in question it doesn’t need to be wound round a straight stip of it would suffice |
Ian Parkin | 13/05/2020 15:08:24 |
![]() 1174 forum posts 303 photos | Bill
you ARE on the ball thats exactly what i need how did you find that? Ian |
