Chuck key for Fish chuck ?
Bootlegger Blacky30/04/2020 20:50:21
54 forum posts
11 photos
Hello,I have a drill chuck made by ,I think,USA company called Fish.
the only reference on the body is,,FISH 1-13.
its quite well made and larger than your Jacobs type,but I am unable to find a key that fits,,anyone out there with one ?
cheers.
Michael Gilligan30/04/2020 21:02:37
23121 forum posts
1360 photos
Never heard of them before
Sorry, I can’t help; except to say that at least one other example seems to exist: **LINK**
https://www.ebay.co.uk/itm/Fish-Drill-Chuck-1-13mm-Capacity/282868400981
... and the key looks fairly typical.
What exactly is the problem ? ... Pin size or the gear
Bootlegger Blacky01/05/2020 09:27:40
54 forum posts
11 photos
2581cfcf-d18c-4d34-91e0-1abb1a8d536b.jpegPin size is 5/16”. The nearest key I have is a Jacobs 5/16” @20.5mm.diameter. But it looks like I need something like 22mm.
Martin W01/05/2020 10:20:14
940 forum posts
30 photos
How about finding a chuck key with the required gear size and then turn the spigot down to the required size to fit the chuck. It doesn't have to be particularly accurate so could be done quickly on a lathe or even with a bit of careful filing in a vice.
Martin
DC31k01/05/2020 10:31:04
1186 forum posts
11 photos
There is a list of Jacobs keys and their dimensions at:
https://www.newmantools.com/jacobs/keys.htm
If the key is does not engage the teeth on the chuck sleeve, you can press the sleeve forward slightly to close up the gear mesh. Conversely, if you have a key where the mesh is too tight, you press the sleeve backwards a little.
ega01/05/2020 10:56:58
2805 forum posts
219 photos
Is this the Austrian (?) firm that makes premium wood drill bits?
Howard Lewis01/05/2020 14:41:51
7227 forum posts
21 photos
I have done just what Martin W suggests to modify a chuck key. Rightly or wrongly, I made the spigot a snug fit in the hole in the chuck body (tighter than the "genuine article" sometimes appears to be! )
HTH
Bootlegger Blacky01/05/2020 18:54:28
54 forum posts
11 photos
EGA..I think the Austrian company might be Fiche.not related.
Martin W,,I think you could be right,but how do I require the right gear size?
on the other hand..do you think I could press the chuck collar down a bit to engage more with the key I have ?
Thanks again for all the replies.
