Making M Type Drummond lathe cross slide leadscrew nut.
David George 118/04/2020 18:19:57
2110 forum posts
565 photos
With the lockdown I thought that I would make a couple of spare nuts for repairing worn threads in crosslide casting. The thread us cut straight into the casting so when wear becomes to much the only option is to bore out and replace with a phos bronze bush.
Screw cut and tap and check with leadscrew.
David
old mart18/04/2020 18:47:53
4655 forum posts
304 photos
Is that a RH square thread?
David George 118/04/2020 19:06:23
2110 forum posts
565 photos
Yes Old Mart it's a 1/2 inch OD 10 TPI RH square thread.
David
Edited By David George 1 on 18/04/2020 19:08:31
old mart18/04/2020 19:28:00
4655 forum posts
304 photos
I would have expected a left hand thread with a cross slide. Is the nut attached to the saddle?
Edited By old mart on 18/04/2020 19:29:30
geoff walker 118/04/2020 19:29:48
521 forum posts
217 photos
Good idea David.
something I need to do but never get round to it.
When you say screw cut AND tap what do you mean?
Geoff
not done it yet18/04/2020 19:40:13
7517 forum posts
20 photos
  • I would have thought that brass or even (ordinary) bronze, would impart less wear on the lead screw. Very few would consider making a lead screw nut in phosphor bronze.
David George 118/04/2020 20:50:29
2110 forum posts
565 photos
I made a finnish tap from silver steel hardened and tempered just t make sure i can repeat sizes.
David
geoff walker 119/04/2020 12:45:59
521 forum posts
217 photos
Hi David
OK, I'm with you now and I can also now see the tap in the first photo.
So presumably you machine the thread almost to size and skim out a small amount with the tap, good idea.
Have you already fitted a nut to your M?
If so I would be interested to know how you held the saddle then bored out to size for the nut.
Geoff
geoff walker 119/04/2020 12:49:07
521 forum posts
217 photos
David
Just had a look at your photo album.
Nice work
Geoff
David George 119/04/2020 13:44:06
2110 forum posts
565 photos
To fitt the new nut. The saddle was stripped and removed and set up in the mill against an angle plate, picked up the centre and bored through. The head recess was machined at the same time and the screw holes for the retaining screws. The bush was locktited in and screws fitted, job done.
David
geoff walker 119/04/2020 17:43:03
521 forum posts
217 photos
Thanks David
I've sent you an email.
Geoff
