Workflow
Keith Gaunt05/04/2020 16:42:43
12 forum posts
9 photos
Hello
For my first project on the WM180 I decided after watching YouTube to have a go at turning new handles starting with the carriage handwheel. However the only metal I had available was a bit of rebar so that's what I used. My workflow was as below but I was a little uncomfortable with the last three steps which didn't seem quite right.
I wanted to ask if there is a more logical sequence to follow, and how should these tasks be approached. As it turned out (no pun intended) I was quite happy with the result, but as I said the method didn't seem quite right and was it more luck than judgement.
1) Remove deformities from surface
2) Drill 8mm hole through to take original screw and widen at end to accomodate screw caphead. this widening was made a little deeper so that the handle could be made longer than the original.
3) Chamfer edge of piece.
4) Knurl along length for handle.
5) Set required angle on compound slide and turn taper from knurling towards the chuck.
6) Measure required length of handle and part off.
Here are photos to help with the explanation, any advice on this or anything else to do with lathes would be much appreciated.
SillyOldDuffer05/04/2020 17:14:02
10668 forum posts
2415 photos
Good result Keith, and exactly how I would have done it.
If you'd hit bother, I'd have said nasty things about turning rebar. Apart from the need to hack back to a smooth surface, the specification of the steel is unknown. Whatever grade of steel is in your particular example, it's structural, not meant to be machined. Using it is a bet, not a safe engineering choice.
The gamble paid off, but poor choice of metal can cause awful grief! I advise against beginners turning scrap because they can't tell if bad results are due to them, the lathe, tool-settings, or duff material. Easier to work with scrap after building experience with friendlier metals intended to be machined.
I had a bad experience early on - unknown to me all the scrap in my junk box was Awkwardcussium. For a while I thought my lathe was incapable of cutting metal. So much more straightforward when I defeated my mean streak and bought suitable Aluminium, Mild Steel and Brass from my local emporium.
Spurry05/04/2020 17:20:14
227 forum posts
72 photos
My method would be 1,3,4, then 2. But there is always another way to do anything....
Pete
Howard Lewis05/04/2020 17:34:04
7227 forum posts
21 photos
You have done well!
Rebar is usually horrid stuff to machine!
What's the secret? Speeds? Tooling?
Keith Gaunt05/04/2020 17:53:33
12 forum posts
9 photos
Thanks for that Dave, it just felt like i was going the wrong way with the taper, but then again it all feels a bit unnatural at the moment, got to think about every move.
Regarding your other point about the rebar, I've taken that on board and I'll wait until my assortment of other metal arrives before doing anything else. Watch some more YouTube.
Keith
Keith Gaunt05/04/2020 18:01:37
12 forum posts
9 photos
Hello Pete
Youv'e prompted me to try and make some soft shield things for the chuck jaws, although thinking about it I wouldn't have needed them even if I had done it your way, but thanks anyway it'll be something to do while waiting for stock to be delivered.
Keith
Bob Stevenson05/04/2020 18:05:47
579 forum posts
7 photos
Actually, if you want to do the best work you will never lose the "think about every move" scenario as it is vital to success!
I like my WM180 a lot but it's main downside is that chuck changes tend to be difficult and irritating due to the threaaded nuts method of chuck fixing,..... a feature of many Chinese lathes........so, one tends to put on the 4-jaw and do the 4-jaw parts of several turning jobs before setting up the lathe for the next operation. This means that one tends to work of several items at teh same time which I often find annoying.
Bazyle05/04/2020 18:10:28
6956 forum posts
229 photos
Nice result. You left out last step - setting topslide back to parallel laugh
Neil Wyatt05/04/2020 18:49:45
19226 forum posts
749 photos
86 articles
Yep, nice result.
That said I always knurl before chamfering etc. because I get a crisper result that way round.
Spurry05/04/2020 18:54:59
227 forum posts
72 photos
Keith
The only reason I mentioned Another Way, was to drill the hole (therefore weakening the piece) after the knurling operation. I always find the knurling the tricky bit, so if it goes wrong, just start again, with the least amount of work.
You are doing very well for first efforts, I agree.
Pete
PS Next job, another handle for the cross slide?
Ian Skeldon 205/04/2020 19:05:00
543 forum posts
54 photos
Great result mate, I am with Neil I would taper and chamfer after knurling and possibly use a piece of leather to protect the knurled part if needed.
Jeff Dayman05/04/2020 19:24:33
2356 forum posts
47 photos
Well however you did it, it turned out well! Don't change too much about how you did things.
Nigel Graham 206/04/2020 00:56:53
3293 forum posts
112 photos
Very smart they are too, Keith.
I'd probably have followed the same sequence, but I do note the suggestion of knurling before drilling.
One thing not mentioned... don't use your best self-centring chucks for turning rough stock. It puts unfair, unequal stresses on the chuck. Use a 4-jaw independent chuck.
As for what Dave called Awkwardcussium... I expect we've all been there. In my case not long ago with some 18mm diameter supposedly-mild steel (well, it was rusty outside and silvery-grey inside) from a scrapped cable-drum tie-rod. I thought it is just plain old drawn EN3. Perhaps it is, but it proved as tough as old boots and would not yield a decent finish no matter what I did, and I had to find some better metal. Even so I do have one use for that Mild-Awk~, but requiring only facing, drilling and tapping the ends and simply cleaning and painting the surface.
Keith Gaunt06/04/2020 12:37:19
12 forum posts
9 photos
Thanks to all your responses, I've learned quite a bit from them and gained a lot of food for thought from each.
Stay safe.
Keith
