Making a mini safe
Steviegtr | 13/03/2020 00:53:47 |
![]() 2668 forum posts 352 photos | Thought some of you might like to see a master at work. I am sure others will dis it but I thought he was pretty dam good. Steve. |
Joseph Noci 1 | 13/03/2020 05:45:46 |
1323 forum posts 1431 photos | Neat work, esp as a machining exercise! Instead of trying to rob its contents, though, just take the whole safe home to your lathe - or drill press..
I.M. OUTAHERE | 13/03/2020 06:49:34 |
1468 forum posts 3 photos | Not Dissing it but .. I always get a chuckle when they use cutting fluid with carbide tooling but not when drilling with a HSS drill which would benefit more especially on stainless . |
Joseph Noci 1 | 13/03/2020 07:14:55 |
1323 forum posts 1431 photos | Posted by XD 351 on 13/03/2020 06:49:34:
Not Dissing it but .. I always get a chuckle when they use cutting fluid with carbide tooling but not when drilling with a HSS drill which would benefit more especially on stainless . I must be blind! I tried to find where the cutting fluid was used with the carbide tooling and could not! But I did see quite reasonable amounts of cutting/lubrication oil in all the drilling operations. Joe |
I.M. OUTAHERE | 13/03/2020 07:40:51 |
1468 forum posts 3 photos | I watched this again for the 3rd time and the only time you will see him applying cutting fluid with a brush is in the first scene where he faces the stainless bolt - after that it is all dry . |
Hollowpoint | 13/03/2020 09:29:28 |
550 forum posts 77 photos | I've said it before but it's very satisfying see what people can do with even the smallest of machines. From what I can see he used sherline machines and just a drill press. |
Joseph Noci 1 | 13/03/2020 10:24:08 |
1323 forum posts 1431 photos | Posted by XD 351 on 13/03/2020 07:40:51:
I watched this again for the 3rd time and the only time you will see him applying cutting fluid with a brush is in the first scene where he faces the stainless bolt - after that it is all dry . Not wishing to be pedantic..Look at 1:24 thru 1:34 or so - clearly see oil running down the sides of the cylinder while drilling. Just cos we did not see the brush does mean it was not applied. - a Chap with the skills he has would do the job right, I think.. |
I.M. OUTAHERE | 14/03/2020 05:54:05 |
1468 forum posts 3 photos | Posted by Joseph Noci 1 on 13/03/2020 10:24:08:
I watched this again for the 3rd time and the only time you will see him applying cutting fluid with a brush is in the first scene where he faces the stainless bolt - after that it is all dry . Not wishing to be pedantic..Look at 1:24 thru 1:34 or so - clearly see oil running down the sides of the cylinder while drilling. Just cos we did not see the brush does mean it was not applied. - a Chap with the skills he has would do the job right, I think.. Right you are Joe ! This time i watched with me glasses on I also noticed what could be some smoke coming off the lathe tool in the machining operations that were shown speeded up so he may have had some fluid on in those operations as well. Looks like he has a cnc Sherline lathe and possibly a cnc mill also. |
Plasma | 14/03/2020 19:01:06 |
443 forum posts 1 photos | Looks a very neat bit of machining. Love the way he marked the characters on the chapter rings with a vice as a press. Not sure I would want to spend that much time on something you could only store a tenner in lol.
