How to do 100 divisions
For new handwheels
steamdave10/02/2020 15:37:49
526 forum posts
45 photos
I want to replace the handwheels on my Myford S7 with the GHT design. What is a suitable way to make the 100 divisions on a gear box equipped S7? I don't have a dividing head that fits on the lathe.
The Emerald Isle
Howard Lewis10/02/2020 15:58:44
7227 forum posts
21 photos
Suggested by someone else, so not original suggestion is:
Fix a 50T gear to the mandrel.
Hold the embryo dial on an arbor in the chuck.
Make up a detent to be a tight fit between the teeth,
While you are about it, make up another that locates symmetrically on the flanks of the tooth
Use one detent to position the dial, to make 50 marks.
Without disturbing anything else, fit the second detent into the holder.
Unlock the mandrel.
Locate the now unlocked mandrel, and make 50 more marks.
Hopefully, there will be 100 marks, equally spaced around you new dial.
Howard.
Neil Wyatt10/02/2020 17:12:06
19226 forum posts
749 photos
86 articles
It's easy to fit change gears to a plug in the back of the mandrel, I did this for my mini lathe, combined with a mandrel handle.
You can also make a detent in the form of a forked peg, which is what I did. One way it fits between teeth, the other it fits over a tooth.
Roderick Jenkins10/02/2020 17:15:09
2376 forum posts
800 photos
OP says his lathe has gearbox...
ega10/02/2020 17:50:52
2805 forum posts
219 photos
Posted by Roderick Jenkins on 10/02/2020 17:15:09:
Presumably implying that he has no change gears that are accessible for this purpose they being, as Martin Cleeve would say, locked up in his gear box.
Obviously, the gear box would prevent the use of change gears if available.
ega10/02/2020 18:22:38
2805 forum posts
219 photos
Too late to edit; I meant to say would *not* prevent.
jason udall10/02/2020 19:54:40
2032 forum posts
41 photos
Who ever put the "add posting button " tight to the terms and conditions link ...not for the first time have I lost an erudite and illuminating post at the last herdal...
Back to point.... either
Take circumference by wrapping strip of paper
Divide this length with drafting techniques..transfer these divisions back to wheel.
Or
Turn wheel to have circumference yielding convenient division
Or use cad to divided wheel and print paper strip.
Glue down and over varnish.
The latter works for me ..also get better contrast for my tired eyes.
Edited By jason udall on 10/02/2020 19:57:12
steamdave10/02/2020 21:34:14
526 forum posts
45 photos
Thanks for the suggestions.
I did wonder about using the paper stuck to wood idea, but I will spend the kids inheritance and get a 50 tooth change gear. (The kids don't want the lathe).  I like the idea of the forked detent.
The Emerald Isle
Edited By steamdave on 10/02/2020 21:34:53
Roderick Jenkins10/02/2020 22:10:43
2376 forum posts
800 photos
In which case Dave, perhaps these pics will give some ideas:
Cheers,
Rod
Jouke van der Veen10/02/2020 22:26:48
203 forum posts
19 photos
You could take a thin strip of metal and drill 101 holes in it at equal distance. The distance between the holes is kept constant by using a gauge with two holes in it. The next drilling position is determined by a fixation pin in one hole of the gauge and through the last drilled hole in the strip.
After drilled 101 holes you bend the strip and fixate it first and last hole with a pin. Then you fill the circle with a piece of wood to make a wheel with 100 divisions. The wheel is attached with some kind of plug to the back of the head spindle like Neil described. You still need a pin that falls into the holes of the strip index the wheel.
Above described method is (was) used by clockmakers not having a proper division table for all kinds of “exotic” clock wheels.
Hopper10/02/2020 23:45:15
7881 forum posts
397 photos
You dont have to use a Myford gear. Just buy any cheap 100 tooth gear off ebay etc and make a arbor and detente plunger to suit. A module 1 gear would do the job.
John Haine11/02/2020 09:30:33
5563 forum posts
322 photos
Or I could lend you a division plate...
