Milling plate clamps
Chris Gragson24/01/2020 18:57:43
44 forum posts
25 photos
mill plate.jpgHello, looking for some advice on a clamp kit for a small mill plate I have knocked up & tapped M6, for a Hobbymat. The plate is only 150mm x 100mm
I would appreciate advice on where to enquire for a reasonable cost, I have searched ebay but picking seem to be slim, I might be using the wrong terminology?..
Thanks
Chris
Edited By JasonB on 24/01/2020 19:36:07
Michael Gilligan24/01/2020 19:10:11
23121 forum posts
1360 photos
This doesn’t seem unreasonable: **LINK**
https://www.amazon.com/Rotary-Tables-Milling-Plates-Vertical/dp/B01MUDCGGV
Ian Johnson 124/01/2020 19:15:32
381 forum posts
102 photos
Have a look at this set from Warco. The studs are M6 and will screw directly into your table, but you can make studs out of any M6 bolt or M6 stud iron (all thread)
Ian
Chris Gragson24/01/2020 19:32:14
44 forum posts
25 photos
Thanks both very much! Way better than anything I could find on ebay.
I went for the Warco set as its UK based and same price.
Thanks again cheers Chris
JasonB24/01/2020 19:35:39
Chronos do a M6 set, the Unimat 3 clamps would also fit.
Ian Johnson 124/01/2020 19:38:21
381 forum posts
102 photos
The Warco set is the same one I use on my milling machines, I've made lots of different height / length studs depending on what I want to hold.
Nice job on the plate by the way
Ian
Chris Gragson24/01/2020 20:25:57
44 forum posts
25 photos
Cheers Jason, looks a similar set to the Warco.
Thanks Ian, the plate was cheap & easy enough for me to knock up, however the tooling is starting to add up, but I knew this smiley
Clive Foster24/01/2020 20:56:40
3630 forum posts
128 photos
Chris
Given the small size of the plate and (mostly) small workpieces you may find some home brew additions worth the effort. Although effective bar and step block clamps tend to need fair bit of real estate.
Way back the I had my BCA I made some simple L shape clamps from 8 gauge (4 mm these days) strips perhaps a little under 5/8" wide with a 1/4 clearance slot down the middle of the long side. Lengths of short and long sides were whatever seemed useful. I suspect I made them ad hoc fashion when I had nothing suitable to hand to whatever size I needed for todays job figuring that what suited one job might well do for something else so I'd eventually build up a set. As I recall it the long sides would have been in the region of 1 1/2 to 3 inches, but 2 inches sounds most likely to be a common one, and short sides between 1/8 and 5/8 inch, probably mostly 1/4, 3/8 or 1/2 inch.
I also made some thicker plain bars with a jacking screw at one end. Probably 1/4 inch thick and again between 1/2 and 5/8 inch wide. Similar 1/4 inch clearance slot and similar lengths. Probably 1/4 BSF or 2 BA jacking screw with a permanent, free ly rotating foot on the end. I imagine I put a small groove a suitable distance from the end of the screw, made the foot a similar shape to that on a G-clamp and peened it over to keep it in place. Long time ago tho'.
Where possible bolt through is more effective than clamping although rarely enough on its own as, generally, only one bolt is possible.
Chris Gragson24/01/2020 23:25:44
44 forum posts
25 photos
Clive, I appreciate this and thanks for posting back.
The size scope for milling is small indeed, I need a starting idea of what size material can be reasonably clamped and the initial clamp kit will provide perspective I hope. I'm under no illusion that bespoke clamps and aids will be needed for specific projects but at least I will have a clamp start to practice with.
I have some material sizes that you mention for ad-hoc jigs/ brackets, which could accumulate to a bucket full of useful stuff I hope over time.
Thanks for your advice, much appreciated.
Best Chris
not done it yet25/01/2020 05:24:18
7517 forum posts
20 photos
If I need inspiration I have a look on Harold Hall’s site. There is usually something to be made or modified for the particular purpose.
JasonB25/01/2020 07:07:50
One reason I suggested teh Unimat type is similar to what Clive says as they use a captive jacking screw rather than stepped packing blocks so a lot easier to work with on a vertical surface and easy enough to make from flat bar, in your case just use studs inplace of the tee bolts.
John Haine25/01/2020 08:35:49
5563 forum posts
322 photos
Or look at miteebite.com
Barry Thurgood25/03/2020 17:45:31
5 forum posts
Hi
A little late for the discussion perhaps, I have used Manifold clamp bars from the Triumph range of car engines, the earlier ones are about 1.75” and the later about 1.125”, you may need to grind off the “pimples”
