Trevor Roberts | 13/01/2020 12:25:35 |
8 forum posts | HI Can anyone advise on machining copper. I am working on a boiler and I have trim some plates in the lathe, would I use the same shape of tool as for machining brass? I also have to drill a large number of holes, what would be the best drill bit shape. Should I modify the drill bits as if I was drilling brass? I obviously don't want to 'tear' or otherwise damage my prepared copper plates/barrel. Thanks in advance. Trefor |
JasonB | 13/01/2020 13:11:01 |
![]() 25215 forum posts 3105 photos 1 articles | A tool with more top rake will work better like you would use on aluminium or a **GT insert if you prefer inserts. For larger holes to take bosses and firetubes I would go with a step drill and have never bothered to alter smaller twist drills for brass, bronze or copper. Full fat milk makes a good cutting fluid. |
fizzy | 13/01/2020 13:30:27 |
![]() 1860 forum posts 121 photos | As a full time copper boiler maker I do quite a bit of this.....I only ever use CCGT tips (as per JB) for turning copper as they out perform everything else by a country mile - no grabbing and clean cuts. Standard drills are fine but beware that your holes will all come out slightly under size. You need to lubricate when drilling copper, and it gives a better cut when turning, I use wd40 as it does the whole machind good and doesnt smell bad. Good luck!
Martin Kyte | 13/01/2020 13:40:56 |
![]() 3445 forum posts 62 photos | Lots of rake. Definitely not zero or negative rake as for Brass. Drilling holes, twist drills ground to a brad point wood bit form work well. The sort with a central triangular bit in the middle and the corners proud so they start cutting before the flanks. This gives a clean hole with no burr on the reverse side. regards Martin |
old mart | 13/01/2020 13:45:58 |
4655 forum posts 304 photos | It's always a good idea to try the recommended tooling on any offcuts of the metal first to get a feel for yourself. That way there will be no danger of spoiling the actual workpiece. |
Trevor Roberts | 13/01/2020 15:52:00 |
8 forum posts | Thanks everybody for your replies. I'm going down to the workshop now to do some tests/practice on some scrap copper.
Thanks again Trefor |
