Looking for assistance on scaling the Eureka form relieving tool
David Brown 17 | 10/01/2020 03:16:15 |
3 forum posts | Hello, I am interested is scaling the Eureka form relieving tool so I can use one inch bore blanks. I see that John Stevenson has done this previously by a description in a previous thread. I am wondering if only the dimensions associated indexing sleeve need to be modified for the larger bore or do I need to change the eccentric amount? All input is appreciated! Thanks, Dave
Brian Wood | 10/01/2020 08:44:29 |
2742 forum posts 39 photos | Hello Dave, I tried to do much the same but it finished in tears I'm afraid. I found another way round it after that experience You will need to boost the scale all round for a bigger relieving throw to about 0.075 inches from the design value of 0.030 inches. The eccentric throw can remain the same if you are making a 12 tooth cutter. The areas that need beefing up are the indexing pawls and the sections of the pieces that rotate within each other. Bushing and brass bearing interfaces are essential to avoid 'pick up' and I recommend using gear oil for lubrication of at least EP 80 grade I also recommend gripping the drive boss in a chuck rather that trying to turn between centres Wishing you well and looking forward to reading an article on how it went for you Regards Brian |
David Brown 17 | 10/01/2020 14:51:08 |
3 forum posts | Hello Brian, Thank you for taking the time to respond to my question! I will make the suggested changes and create the drawings. Once finished the drawings I will post them back here to try and help other readers.
Take care, Dave |
Brian Wood | 10/01/2020 17:24:31 |
2742 forum posts 39 photos | Hello David, I wrote up my story for EIM [ Engineering in Miniature] magazine, they were published in two parts last year with Part I the Eureka experience and Part II my alternative hand powered method. My copies are out on loan at the moment so I can't tell you which issues to look out for but I will look out for your drawings with interest. I should have welcomed you to the forum as well today, I hope you find all manner of answers here Kind regards Brian |
Roderick Jenkins | 10/01/2020 17:51:02 |
![]() 2376 forum posts 800 photos | The Eureka device obviously creates a lot of interest. I was astounded to see that my video of the device in action has had over 10,000 views Rod |
John Purdy | 10/01/2020 18:40:35 |
![]() 431 forum posts 252 photos | Dave The issues of EIM that had Brian Wood's articles in were June and July 2019. I've sent you a PM. John |
David Brown 17 | 10/01/2020 19:22:09 |
3 forum posts | Hi Rod, I actually watched your video last night and the video is excellent, the video really helps to understand the function. I would still like to understand the math behind the how the eccentric travels were determined.
Brian Wood | 11/01/2020 08:39:16 |
2742 forum posts 39 photos | Hello David, I don't think there is actually a lot of maths involved in establishing the eccentric motion needed to shape the flanks of cutters. In my two part article in EIM, the June copy [thank you John Purdy for providing the dates for them] in which I described my trials with Eureka, I used a full sized commercial cutter of 2.25 inches in diameter to measure the eccentric amount a button tool needs to carve metal off on a blank. This came to 0.070 inches, a lot more than the design value of 0.030 inches chosen for much smaller gear cutters.. Just as an observation. Rod's video shows the action well but in common with another one I have seen, they both demonstrate the easier task of frontal trimming; not the more demanding task of shaping. It would be intersting to observe the performance in that task Brian. |
