2020 Had my full size flash steam engine running
Windy05/01/2020 15:56:32
910 forum posts
197 photos
Had my full size flash steam engine running yesterday on compressed air unfortunately have not got too much pressure and quantity for high rpm so just a pop, pop at low rpm.
Had to retard inlet poppet valve and use compression release valve to enable it to run with my limited compressor also added temporally extra mass to crankshaft for this test a lathe chuck.
Would run on about 90psi with this setup but need a lot more pressure to run on the proper valve settings..
Neil Wyatt05/01/2020 18:39:35
19226 forum posts
749 photos
86 articles
Crikey folks, clear the runway.... Windy's coming through....
Big milestone, when does it go in a frame?
Windy05/01/2020 23:08:29
910 forum posts
197 photos
Another test running on compressed air.
Windy08/01/2020 14:19:24
910 forum posts
197 photos
Not sure if my link worked on my slow speed test runs so will try this.
Howard Lewis08/01/2020 14:42:40
7227 forum posts
21 photos
Very Good. Obviously expanding nicely, judged by the condensate in the exhaust.
Wondered why the Tacho case was in the swarf tray of the Myford, but found out towards the end of the video.
Should be quite something after fine tuning!
duncan webster08/01/2020 15:33:08
5307 forum posts
83 photos
Wonderful! Is the poppet valve pressure balanced in any way, or does it just open against HP steam?
Windy08/01/2020 17:28:57
910 forum posts
197 photos
Posted by duncan webster on 08/01/2020 15:33:08:
Afraid not I played about with them in my early days with the model but have high rpm to contend with.
Discussing this with my steam rocket drag motorcycle friend when his poppet valves went wrong against tons of water pressure.
We came up with a very simple nearly balanced poppet valves they would probably be ok at slow speed openings.
He decided on a butterfly type valve instead from America that their water, steam rocket people use successfully.
The successfully Canyon jump machine jets were similar to his rocket motorcycle power unit.
Edited By Windy on 08/01/2020 17:31:52
Windy14/01/2020 01:28:35
910 forum posts
197 photos
Have been looking at full size water pump pulsation dampeners the industrial ones would make a hole in my wallet.
Been thinking of certain paint ball and aqua diving bottles that might be a possibility.
They are available in many sizes and pressures to 45000 psi they are aluminium or carbon fibre.
Any thoughts and designs that members might know of.
Would prefer to buy one that is certificated otherwise might make one.
Jeff Dayman14/01/2020 07:01:47
2356 forum posts
47 photos
For a DIY pulsation damper, could you maybe use a piston in a cylinder, working against a spring? (Like a safety valve, but without vents)
Maybe a pneumatic cylinder off the shelf , with a beefier spring? I've seen such cylinders in surplus places going quite cheaply. Many are good for 400 psi plus. Just food for thought.
DiogenesII14/01/2020 07:56:52
859 forum posts
268 photos
Bottles for recharging air rifles come in at least 3,4,5,7 litre, & larger sizes, usually rated 300bar. They like lightweight ones to carry in the field..
Edited By DiogenesII on 14/01/2020 07:57:38
Windy16/06/2022 18:47:50
910 forum posts
197 photos
Had a few delays with health issues but still experimenting with full size flash steamer had a few problems with steam generator burners but sorted them.
Generator is 12 inches diameter and would not self ignite when hot the exhaust outlet was too large cooling it down.
Restricted exhaust outlet and seems fine am only using a small hand pump for initial tests the liquid on bottom burner is a drop of high temperature oil from a connection I lubricated.
New exhaust similar to my proven model design now being made.
This might get to to the video
Edited By Windy on 16/06/2022 18:49:26
Edited By Windy on 16/06/2022 18:55:57
Edited By JasonB on 16/06/2022 19:04:11
Edited By Windy on 16/06/2022 19:12:06
Jeff Dayman16/06/2022 21:19:47
2356 forum posts
47 photos
That's a ferocious looking burner Windy! red hot in just under 25 seconds! Looking forward to seeing engine and boat runs with that one. Thanks for sharing the video. Cheers!
Windy16/06/2022 23:41:28
910 forum posts
197 photos
Posted by Jeff Dayman on 16/06/2022 21:19:47:
It's not for a boat but full size wheeled vehicle either two or three I have all the generator coils ready thanks to another ME and full size record breaker
Neil Wyatt17/06/2022 16:00:43
19226 forum posts
749 photos
86 articles
Good heavens!
You don't need the steam engine, you've got a full functional ramjet right there...
peak427/09/2022 13:18:00
2207 forum posts
210 photos
Re. the steam bike earlier in this thread, for those with Facebook access, this just popped up in my timeline.
It was linked by my old mate driving the recue unit; I think he's going to need a faster ambulance.
See also Force of Nature
http://www.force-of-nature.com/content/home-page
Bill
