my first lathe.
jamie creighton 108/12/2019 13:00:47
25 forum posts
so after looking for a while a hobbymat md65 came up for sale 15 miles away,i went to have a look and bought it.it comes with the milling head attachment and lots of extras such as the slow speed wheels,spare 4 and 3 jaw chucks,a box of collets etc.
i spent a few nights after work cleaning it all up as it had been in a shed for a few years,it has come up very well,i also oiled it and adjusted the gib strips.
so today i spent a few hours having a play and just turned down a bit of steel.
in trying to get a good finishing cut and all seems well except every now and again the tool seems to dig in and leave a faint ring mark.
ive tighten up the beds and that seems to have helped but anymore and the beds are too tight to move smoothly.also the lathe is not bolted down.
any thoughts?
yes i know its in the kitchen,being single has its rewards laugh
Lainchy08/12/2019 13:39:09
273 forum posts
103 photos
What sort of tooling are you using Jamie, and is it bang on centre height?
Paul Kemp08/12/2019 14:04:06
798 forum posts
27 photos
Jamie,
Thats an interesting (strange) looking tool post? Do you (or does anyone else know) if that is original? The downward slope of the tool slots suggests that unless the tool has an interesting ground profile it would have a fairly hefty negative top rake? Or is there another secondary tool holder that fits in the tool post slots and the slope allows adjustment of tool height? Be interested in seeing some more pictures.
My own MD65 must be 40 years old now it was the first lathe I ever owned and I think it's a fantastic little machine. That has the 'round tool post' Over that time it has done jobs that were far too big for it but it will still turn dead parallel over 6" or so.
Paul.
SillyOldDuffer08/12/2019 14:06:37
10668 forum posts
2415 photos
A photo of the tool and work would help. Though I doubt it's the problem the temporary mounting balanced on boards may not be helping. Shouldn't be necessary to tighten the gibs until they actually grip.  Bolting down my mini-lathe didn't make any difference - it was OK on rubber feet.
One thing that jumps out at me is the tool-post with angled slots:
How are you holding the tool in it?
Various possibilities:
Tool blunt or wrongly angled.
Poor steel (Rather a lot of metals don't machine well. Don't test lathes with unknown scrap!)
Tool point extended too far and bending under cutting pressure
Work bending under cutting pressure.
Swarf getting trapped under cutting point. (This causes most of my finish problems.)
Wrong speed & depth-of-cut combination.  (Experiment)
Wants lubrication, especially if tool is HSS.
Bed and or headstock bearings worn. (Should be obvious.)
Edited By SillyOldDuffer on 08/12/2019 14:09:56
jamie creighton 108/12/2019 14:32:15
25 forum posts
Posted by Lainchy on 08/12/2019 13:39:09:
hi,yes the cutter is in the center.for the first few goes i used a rounded tip cutter,sorry i dont know the techical name,then i switched over to this cutter you can see in the pic,i made a much better finish and took finer shavings.i suspect i need to buy some new tooling.
jamie creighton 108/12/2019 14:39:26
25 forum posts
cheers dave for the reply,
i do have the original round tool post,the one in the pic was on it when i bought it,its a quck change type.
the bearings do not appear to have any play,as does the main saddle,the cross feed and tool post gibs were bent out at both ends so i straightened them at work and re adjusted.
what is the larger bolt for in the center on both beds? is that for intially getting the gib strips in the right position?
Edited By jamie creighton 1 on 08/12/2019 14:40:34
SillyOldDuffer08/12/2019 15:11:00
10668 forum posts
2415 photos
Posted by jamie creighton 1 on 08/12/2019 14:39:26:
Just a guess as I've never looked closely at the MD65, but they're probably locking bolts. If so, (and believe an MD65 owner if he contradicts me ), then the gibs are set with them slackened,using only the screws with lock-nuts. May be a bit of a fiddle to set the gibs evenly with these so the slides don't bind at one end or in the middle of their travel. The gibs should be tight enough to stop the slides slopping about but not tight enough to make it hard to turn the controls.
Lock bolts on gibs aren't an adjustment. Rather they can be tightened to lock a slide in a fixed position as a way of eliminating accidental movement whenever that particular slide doesn't need to move. For example it's worth stopping the top-slide moving right-left when facing off front-to-back. Not sure about the MD65 but there may be a bolt or Allen Key on the saddle that locks it to the bed, again useful to reduce accidental movement.
Good practice to check locks are on or off correctly before using the lathe to take a cut. Lathes don't like cutting under power with the saddle locked!
jamie creighton 108/12/2019 15:17:48
25 forum posts
nice one cheers,that makes sense.
could someone link to some good quality tooling i can buy please? ive been looking but there's too much choice,whats best?
good old hss or the ones with throw away cutting tips?
magpie08/12/2019 16:28:13
508 forum posts
98 photos
Hi Jamie. I had a MD65 some years ago but sold it when I needed to work bigger things. There is plenty of good advice on here about any problems you may have. Regarding cutting tools, I use both HSS & tipped tools but these days I only use HSS for plastics. Lots of tipped tools to be had from lots of suppliers and my main reason for using them is because I am getting very lazy in my old age, and can't be bothered re-grinding HSS despite having a Quorn. JB cutting tools would be a good place to look for tipped tools and their various tips for different jobs. I have no connection to them, just a satisfied customer.
Bazyle08/12/2019 18:16:08
6956 forum posts
229 photos
100% the oddest toolpost I have ever seen, I suggest going back to the original round one for the moment.
I take it you are doing auto feed when the problem occurs because if you are manual feeding even changes is speed of hand movement can show up. There is always some backlash on the cross-slide however tightly the gibs are set and well the screw is adjusted. On the final cut lock the cross and top slides.
jamie creighton 108/12/2019 18:58:10
25 forum posts
thanks,i will put the original one back on.
auto feed is being used and i will try it with both slides locked .
Paul Kemp09/12/2019 23:25:53
798 forum posts
27 photos
Jamie,
Thanks for the bigger picture. Never seen a tool post like that before! Can't imagine what advantage it gives, disadvantage I would say is the large negative top rake, not really what you want for steel. I think you will get better results with the conventional round tool post that came as standard, that will give you a zero or positive rake depending how the tool is ground. I get a decent consistent finish without locking slides on mine.
Paul.
jamie creighton 110/12/2019 05:23:38
25 forum posts
Cheers Paul,
I bought a small blank of delrin to have a play at the weekend.
im still not sure what type of tooling to buy, anyone have a link please or a good dealer to buy from please?
Lee Rogers10/12/2019 07:48:14
203 forum posts
Posted by magpie on 08/12/2019 16:28:13:
I think if your just starting out a set of HSS tools will be more forgiving than carbide tips and learn to grind your own. Old hands are only experienced because they've made all the mistakes and have a good memory and I do remember destroying a lot of carbide tips. Enjoy !
Lambton10/12/2019 09:04:08
694 forum posts
Jamie,
In the bigger picture of the strange tool post I notice that at least one of the top slide - cross slide securing screws is very loose. All four screws must tight ( but not over tightened). It is essential to eliminate all looseness if you are to get a good consistent cut.
Eric
SillyOldDuffer10/12/2019 10:50:50
10668 forum posts
2415 photos
Posted by jamie creighton 1 on 10/12/2019 05:23:38:
Cheers Paul,
Beware of plastics and metals difficult to machine! My start as a total beginner was dogged with problems caused by me assuming a metal-working lathe would obviously cope with anything. Not true! Plastics are usually gummy, pliable and easily damaged by heat. Many metals from finished products will have been carefully selected to suit a particular purpose and manufacturing process; zero consideration is given to chaps wanting to turn it on a small lathe! For example, aluminium window frames are made from an alloy intended to be extruded, too soft to machine well. There's a lot to learn about machining different materials.
I wasted months as a beginner. I may have been unlucky because my entire collection of scrap metal turned out to be carp. Buying EN1A was a revelation - it's a mild-steel specifically formulated for machining. Plenty of suppliers other than Metal Supermarkets, but their description is worth repeating:
EN1A is a low carbon-manganese free cutting steel suitable for machining using both automatic and CNC machines. EN1A is used for turned components, such as nuts, bolts, studs and hydraulic fittings.
EN1A, also known as 230M07, can be case hardened to produce components with enhanced wear resistance.
EN1A can also be supplied in a leaded grade, EN1A Pb, 230M07pb.
The leaded grade is particularly good for turning, it's about twice as machinable as ordinary mild steel.
Same advice when buying other metals especially Stainless Steel, Aluminium and Bronze: look for 'free-cutting' or 'suitable for machining' in the specification. Brasses are also somewhat variable, but they all seem to turn OK in a lathe. Plastics too need research.
The ground steel rods from old printers and scanners mostly turn well, but I have one that's incredibly hard. Tricky for beginners to identify if problems are down to the lathe, tool, material, or the operator. In the absence of a tutor, this forum, books, and YouTube all help, but be prepared to experiment.
Tools are another controversial subject. Personally I see little point in buying expensive high-end industrial cutters for occasional light use in my garage! Nor do I like the risk of buying from unknown web-sellers because there's more risk of factory rejects, 'too cheap' and counterfeit. (But people do get genuine bargains off ebay!)
I prefer established UK based sellers. Mostly ArcEuroTrade, Warco and Tracy Tools (for Drills, Taps & Dies), but I've also used RDG, MachineMart and several others without grief. While hobby vendors rarely sell the best possible tools they're OK for my purposes. (The reason the best possible tools aren't carried is probably economic. While Model Engineers are keen to own good tools they are rarely prepared to pay full price for them! Impossible, I think, to profit selling good tools to hobbyists because most of 'em have tiny budgets.)
I guess anyone starting with a second-hand MD65 isn't a serious professional machinist intending to make a living from it. Compromise is the order of the day. As a beginner my advice is avoid cheap and nasty, and don't get hung up on 'quality'.
There's debate about HSS vs Carbide. HSS is more general purpose, but it needs to be kept sharp. That means buying a grinder and learning how to use it! There are chaps who find grinding easy, others - like me - struggle. Carbide inserts avoid sharpening problems: tad expensive to buy but very easy to use. I mostly use Carbide for convenience (at least 80% of the time) but switch to HSS when carbide doesn't produce a good finish(rare), or when a specially shaped tool is needed for awkward corners or fine work. Depends on what you're doing. Owners of powerful fast lathes turning big lumps will likely prefer carbide, small lathes used for delicate work will probably do better with HSS, as will big slow lathes. I used carbide OK on a mini-lathe, which is similar size/speed to the MD65, but I wasn't making clocks!
Carbide inserts are available in a deeply confusing multitude of sizes and shapes. Hobby suppliers like ArcEuroTrade tend to stock the types useful to hobbyists, and you won't go far wrong buying them. Chaps who know what they're doing never recommend sets, but I recommend sets for beginners because beginners seldom know what they need or even exactly what they want a lathe for. Though I'm unlikely to buy a set now, I found sets invaluable for learning.
The December issue of Model Engineer's Workshop Magazine includes a printed ArcEuroTrade Catalogue. Buy one! Both magazine and catalogue give a good idea of what's available and who sells it.
Andrew Johnston10/12/2019 11:01:09
7061 forum posts
719 photos
I'd agree with the crowd; bin the toolpost. The angles of the toolbit are all wrong; you need more side rake.
I'd start with HSS toolbits and a bench grinder. You can ignore complicated grinding fixtures, a simple knife tool is only three angles, none of which are critical. Insert tooling can be tricky to get a good finish and is more expensive than HSS toolbits. I'd agree with SoD, know your material. If it's out of the scrap bin all bets are off; you may never get a good finish. Ideally start with EN1A; it's fairly simple to get a good finish. On the other hand EN3B, which is a common low carbon steel, can be difficult as it is slightly "sticky" and has a tendency to tear.
Andrew Johnston10/12/2019 11:10:14
7061 forum posts
719 photos
Bother, beaten to it by SoD!
But I bet he can't compete in the kitchen, sorry assembly shop, stakes. I used to have a lathe on the kitchen table, as well as a number of other engineering items in the kitchen:
Now that I've had a new kitchen fitted the engineering stuff has migrated to the hall and sitting room.
jamie creighton 110/12/2019 17:38:06
25 forum posts
many thanks fella's,ive ordered a set of hhs tools to get me started and also a small round bar of bronze to have a play with.
just how sharp do the tools need to be? do they require further honing?
not a problem if they do,i still have my wet stones from my cabinet making days,back then i always had a bald patch on my arm as i used the hair to gauge the sharpness lol
Bazyle10/12/2019 18:27:16
6956 forum posts
229 photos
Out of the frying pan etc. You know bronze is one of the difficult ones, it snatches tools and also work hardens. Don't risk drilling it until you understand it and have worked out how you will remove the broken drill. surprise
