Member postings for jamie creighton 1
Here is a list of all the postings jamie creighton 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: turntable spindle bearings
07/05/2022 16:19:48
so following on from my earlier thread i had a go at making some spindle bearings in torlon today.
it seemed to go well and i enjoyed it a lot. heres a video showing rthe run out when the turntable is spinning. what do you guys think? click on the phto to see the vid
Edited By jamie creighton 1 on 07/05/2022 16:20:27
Thread: making spindle bearings
03/05/2022 17:49:42
the question is in this day and age are oilites a good choice? modern engineering plastics or lignum vitae wood seem a better choice. im no expert though.
Edited By jamie creighton 1 on 03/05/2022 17:50:03
03/05/2022 17:47:34
thanks for all you comments so far
i mentioned earlier that i have a spare spindle,i have cut it at an angle to turn it into a toolmakers reamer,has anyone tried this approach?
also if i do use oilites they will have to be machined as the size is not a off the shelf item. the benefits of using torlon is the improvemnt in sound quality due to less noise in the form of distortion picked up by the the stylus.
there are a few options to think about though so nothing is set in stone.
Mike thats the same as this turntable,the spindle uses 2 bearings and the weight is suppoted by a thrust pad.
02/05/2022 14:34:36
bringing an old classic turntable up to date,rare, exotic and top end japanese direct drive, still good by todays standards.. it uses oilites as standard,id like to try and better the tolerances. i have spares so no harm will come to it while i practise. the end goal will be to substitute the oilites for bearing grade torlon.
the plinth i made myself,its panzerholz veneered in cocobolo.
Edited By jamie creighton 1 on 02/05/2022 14:42:43
02/05/2022 14:23:10
Posted by Hopper on 02/05/2022 12:03:52:
Are you designing and/or making your own turntable or repairing an existing one? Aiming at high-end audiophile performance or just want to crank up Black Sabbath until you can't hear your neighbours banging on your front d
oor?
02/05/2022 11:26:12
thanks hopper,yes it for a turntable.
im measuring the spindle with a digital micrometer whic is reading 10.985,is that classed as 11mm norminal?
anyway i believe an h7 11mm reamer is the correct size?
sorry for the dum questions but id like to get this as accurate as possible .
02/05/2022 11:20:26
sorry i should have been more clear,the bearings im hoping to make are not for the lathe,the clues in the rpm of the spindle, 33 1/3
02/05/2022 10:58:32
hi,yes thats what im going to do first but being new at this i thought the final hole finish should be reamed?
02/05/2022 10:41:52
ok,
the spindle measures 10.985mm so im thinking an 11mm h7 reamer work do it? the spindle only turns at 33. 1/3 rpm.
02/05/2022 10:19:27
hello all,
id like some information please on the best set up and method for making spindle bearings. i need 2 from bronze .
i have a spare spindle which can be made into a toolmakers reamer and my lathe is a hobbymat md65,i also have the milling machine attachment.
i was thinking of buying a floating reamer head attachment as id like to get a good tolerances.
what do you think? whats the best way forward please?
cheers.
Thread: my first lathe.
11/12/2019 17:15:55
well all i know is it came already mounted on the lathe and as i said previously the original oem one has been put back on
10/12/2019 18:44:53
im a great believer in just having a go,you learn from your mistakes,well some people do lol
10/12/2019 17:38:06
many thanks fella's,ive ordered a set of hhs tools to get me started and also a small round bar of bronze to have a play with.
just how sharp do the tools need to be? do they require further honing?
not a problem if they do,i still have my wet stones from my cabinet making days,back then i always had a bald patch on my arm as i used the hair to gauge the sharpness lol
10/12/2019 05:23:38
Cheers Paul,
I bought a small blank of delrin to have a play at the weekend.
im still not sure what type of tooling to buy, anyone have a link please or a good dealer to buy from please?
08/12/2019 18:58:10
thanks,i will put the original one back on.
auto feed is being used and i will try it with both slides locked .
08/12/2019 15:17:48
nice one cheers,that makes sense.
could someone link to some good quality tooling i can buy please? ive been looking but there's too much choice,whats best?
good old hss or the ones with throw away cutting tips?
08/12/2019 14:39:26
cheers dave for the reply,
i do have the original round tool post,the one in the pic was on it when i bought it,its a quck change type.
the bearings do not appear to have any play,as does the main saddle,the cross feed and tool post gibs were bent out at both ends so i straightened them at work and re adjusted.
what is the larger bolt for in the center on both beds? is that for intially getting the gib strips in the right position?
Edited By jamie creighton 1 on 08/12/2019 14:40:34
08/12/2019 14:32:15
Posted by Lainchy on 08/12/2019 13:39:09:
What sort of tooling are you using Jamie, and is it bang on centre height?
hi,yes the cutter is in the center.for the first few goes i used a rounded tip cutter,sorry i dont know the techical name,then i switched over to this cutter you can see in the pic,i made a much better finish and took finer shavings.i suspect i need to buy some new tooling.
08/12/2019 13:00:47
so after looking for a while a hobbymat md65 came up for sale 15 miles away,i went to have a look and bought it.it comes with the milling head attachment and lots of extras such as the slow speed wheels,spare 4 and 3 jaw chucks,a box of collets etc.
i spent a few nights after work cleaning it all up as it had been in a shed for a few years,it has come up very well,i also oiled it and adjusted the gib strips.
so today i spent a few hours having a play and just turned down a bit of steel.
in trying to get a good finishing cut and all seems well except every now and again the tool seems to dig in and leave a faint ring mark.
ive tighten up the beds and that seems to have helped but anymore and the beds are too tight to move smoothly.also the lathe is not bolted down.
any thoughts?
yes i know its in the kitchen,being single has its rewards laugh
Thread: which lathe?
28/11/2019 17:08:25
Posted by SillyOldDuffer on 28/11/2019 12:00:35:
Posted by jamie creighton 1 on 28/11/2019 05:26:46:
But I recommend focussing on what exactly is essential in the way of 'tight tolerances'. In practice, when making a simple bearing, I doubt many of us would insist on a machine capable of working to tight tolerances in the sense used in manufacturing were it's important to make parts interchangeable.
A slightly different technique considerably reduces the need for sooper-dooper machinery. Parts aren't reproduced from their measurements directly. For example, this bearing could be made by first drilling a hole slightly undersize through bronze, brass or oilite rod and then carefully boring the hole out to size. Likewise the outer diameter would be turned slightly oversize, and then carefully removing excess metal until the part fits into the turntable. In both cases 'size' is judged by reference to the shaft it's intended to fit, and the hole in the turntable. There's no requirement for lathe's dials to be spot on. When working by comparison, any lathe in reasonable condition will do the job.
cheers dave,
thats basically my thoughts on how to do it .
just to clear the is or isn't it an oilites bearing up here's a video of myself putting the oil back in them under vaccum.
you can see the air being removed from the bearings so the oil can get into the pours.
many thanks for your replies so far
