Decent drawings for an LNER A-3
Craig Theobald03/12/2019 11:38:41
3 forum posts
Hello all
First post here so I'll introduce myself first. Craig is the name and I'm an ex injection mould toolmaker with a pretty decent range of machines in my home workshop which I'm looking to put to use in producing a 5" steam loco.
I have aquired a part started A4 Pacific loco in 5" gauge, basically just the chassis rails, cross members and buffer beams for the loco and the tender in 5" gauge. I think it may have been a part built Modelworks kit but not certain.
Anyway, I'd like to finish or at least continue the build but not a huge fan of the A4 locos so was hoping the bits I have are more or less the same on a Flying Scotsman type, A3 loco?
If I can build an A3 onto these chassis rails does anyone produce a good set of drawings for them? I have seen the Clarksons catalogue on Blackgates website and they state they were produced in the 1970's. Are these still a good set of drawings or has anyone produced a better set since then?
Complete drawings of all parts would be ideal and if there is the option of a metric set, I'd take them...
Many thanks
Craig.
Weary03/12/2019 13:54:56
421 forum posts
Doncaster; designed by Don Young.
Drawings and castings available from Reeves 2000. Drawings imperial.
Constructional series in Locomotives Large and Small magazine (I think).
Build log and enthusiasts for same who may be of assistance on Model Engineering Clearing House forum.
Regards.
Phil
Peter Layfield03/12/2019 14:52:54
37 forum posts
I would support the post from Weary, many say that they were the most detailed and accurate drawings produced
for a 5" gauge A3, your castings will easily meet the measurements for the
A3 drawings
duncan webster03/12/2019 15:54:31
5307 forum posts
83 photos
I think Michael Breeze drawings also available from Blackgates, no idea how good or bad they are
David George 104/12/2019 05:15:26
2110 forum posts
565 photos
Hi Craig welcome to the forum. Where are you based it helps with local suplier etc being a retired toolmaker myself i was interested what machinery you have.
David
Simon Collier04/12/2019 08:36:14
525 forum posts
65 photos
This extremely detailed build log of the A3, using the design of Don Young, should be enough to scare you off. The quality of Pete's work is amazing
http://modeleng.proboards.com/thread/5733/building-don-youngs-doncaster
Craig Theobald04/12/2019 10:06:29
3 forum posts
Many thanks all
Those drawings of Doncaster certainly look like what I'm after. I'll speak to Reeves soon and see if I can get a set ordered up.
I will read through that thread Simon but having a quick look it certainly is something to aspire too, very nice work going on there.
I was lucky recently to assist with the clearance of a closing down workshop and managed to get myself a Colchester Bantam lathe and a very clean Bridgeport series 1 mill. All came from a university department so not heavily used, digital readouts and plenty of tooling to go with them. Bridgeport has the key way cutting head on the back too which will be a new thing for me to try out.
Cost a fair bit for a 3 phase inverter big enough to run them as intended but, well worth the money in the end.
I have a 3" scale Burrell traction engine to rebuild first. It's a very well used model and needs the crank journals re-turning and new bearings making for it and I may have to remake the tender due to corrosion. It is a steel boiler and a couple of the stays may need milling out and replacing too but will be a good project to cut my teeth on as it were.
Craig.
Craig Theobald04/12/2019 10:08:17
3 forum posts
Oh, I'm based in West Sussex not too far from Horsham. I know the Guildford club quite well as I used to help out with the gala weekend there running the traction engine field.
Craig.
