Mini Lathe Upgrade
COLIN MARTIN 223/11/2019 14:16:43
54 forum posts
Hi All,
Apologies for the subject, but I'm interested in other member's experiences along the same route.
I have a Conquest mini lathe that has served me well over about fifteen years, making and modifying motorcycle parts, but two points are a problem: the 80mm chuck is too small, and the poor headstock rigidity makes parting off a real problem. I am considering changing to a 100mm chuck and replacing the bearings with angular thrust ones, but I'm not sure if the 300w motor is going to be beefy enough.
So, I am considering a new mini lathe, which comes with the 100mm chuck and more powerful motor, but by the time all the extras like 4 jaw chuck, faceplate and steadies are added, works out at about £700. Alternatively, I can buy a Chester DB7VS, which comes with the four jaw chuck, faceplate and two steadies for about the same money. Any opinions please? Should I look for a Myford ML10 instead? Thank you.
Neil Wyatt23/11/2019 17:02:34
19226 forum posts
749 photos
86 articles
Hi Colin,
I'd be inclined to get a brushless mini lathe with standard size chuck and use a 100mm chuck with a backplate.
You can then use your existing 80mm chuck(s) faceplates and accessories and also have the advantage they can be used over the cross slide.
There are few, if any, disadvantages of using a 100mm chuck with a backplate.
This is how my mini lathe is set up, which is an ancient CL300M upgraded with roller bearings and also fitted with a half-horse 3-phase motor.
After fitting the bearing upgrade I never had any real issues with parting off.
COLIN MARTIN 223/11/2019 17:38:03
54 forum posts
Hi Neil,
Thanks, I suppose we have all been in the position of being caught in a dilemma. I'm mulling things over in my head!
Colin
Bob Stevenson23/11/2019 17:52:46
579 forum posts
7 photos
I used a Conquest mini-lathe for about 10 years but changed two years ago to a Warco WM180 which is a sibling machine to DB7. I liked my mini-lathe and have defended mini-lathe on this forum, however, the WM180 is vastly superior in just about every way and I have been delighted with it's many improvements over mini-lathe.
Lainchy23/11/2019 20:41:02
273 forum posts
103 photos
Hi Colin,
I have a DB7, and still struggle with parting off occasionally, mainly in steel, but a 3/32" parting blade seems to work the best. Keep it slow and well lubricated. No problems parting anything else off though. A friend has the SC3 which I believe is similar to the conquest??? and his headstock bearings have been upgraded - it works really well, albeit 500w.
If it were me... and machining motorcycle parts which I assume will be good quality steel, I'd go for either the SC4 or Axminster/Warco/Chester variants (If brushless, and if you can stretch that far budget wise) Not sure about the Myford ML10
I'm a beginner, but personally, if mainly machining Steel... I'd want a bit more grunt, hence the SC4 suggestion.
Hollowpoint24/11/2019 10:16:13
550 forum posts
77 photos
If it was my money I would be looking to upgrade to a larger machine. The mini lathes are OK but they lack rigidity. They do seem to hold there value though so that might help pay for the upgrade.
I can't comment on the db7 because I've never had one. I have had an ML10 though and it's a lovely machine! The biggest drawback as with the ML7 is the limited spindle bore. Not ideal if you are making motorcycle parts. My current lathe is a Boxford AUD which beats the others mentioned hands down. This would be a perfect choice for you as it has a good bore size and my own will part through most stuff with ease. An AUD would set you back £1000+ though. You might be lucky though and find a CUD or BUD within your budget. That would be my suggestion, the difference between your mini lathe and the Boxford would be noticeable.
COLIN MARTIN 224/11/2019 10:48:21
54 forum posts
Thanks everyone for the suggestions. Everything is a compromise between, space, weight, money and size v what I wish to do. There is a Chester retail outlet near me, so I will go along and have a look at a DB7VS, and then spend some time mulling things over.
Ron Laden24/11/2019 15:40:02
2320 forum posts
452 photos
Colin, unless I am missing something the DB7VS is on the Chester site for £838 not £700 and yes it does come with a 4 jaw and the steadies but I dont see a face plate listed. Also it is only a 12 inch machine which is rather small unless you know you wont need anything longer, Chester claim 700 watts and I could be wrong but I think it is a 600 watt motor fitted. I am not trying to put you off or knock the machine it may be a nice little lathe, probably is, but I just thought I would mention those points in case you have missed them.
Have you considered their 920 lathe that is a 9 inch x 20 inch against the 7 inch x 12 inch of the DB7 and £25 cheaper. You mentioned getting over the problems you have with parting off, a bonus on the 920 is that it has a T slotted cross slide which means you could fit a rear tool post for parting. I have a rear tool post on my Warco 920 and parting is a pleasure to do with no issues.
Just a bit of food for thought for when you go to Chesters to see the DB7 have a look at the 920 as well.
Edited By Ron Laden on 24/11/2019 15:41:42
COLIN MARTIN 225/11/2019 08:42:59
54 forum posts
Yes, thanks Ron,
I do think that the Chester 920 looks very good, but I'm worried about the weight as I'm not as young as I was and space is an issue too.
The DB7 appears to be a good buy with all the extras included, but does work out at £100 dearer than a similarly equipped mini lathe. As everyone on here has probably found, a home lathe can never be too big, but practically it is a compromise. I don't want to struggle to get a heavy piece of kit into place, which definitely rules out the small Harrison and Colchester lathes etc. I'm in no rush, so I will keep !y options open.
Lainchy25/11/2019 08:57:51
273 forum posts
103 photos
Keep yer eye's open Colin, I managed to pick up my DB7 with all the tooling and a Chester metal stand for £650. ...although, I had to drive to South Wales to collect it - around 250 miles round trip for me.
Well work it though, as it was 2 years old and only turned aluminium. I kept watching eBay and Gumtree.
Good luck
COLIN MARTIN 228/11/2019 10:16:33
54 forum posts
UPDATE:
after much thought, I've decided that I can only decide after I know what I am going to need!! It is a bit illogical to buy the same size lathe with just a bigger chuck (even though it is a higher spec) without knowing if it will do the job, therefore I have decided to upgrade my existing lathe and see how I get on with that, then go from there.
I have bought a 100mm chuck (on special offer at the moment from Arc Euro Trade) and a pair of angular thrust bearings, which I hope will stiffen up the spindle, and a new spindle with the flange which takes the 100mm chuck. Big thank you to Arc Euro Trade which sent out the parts for next day delivery and Simon at SPG Tools who supplied the spindle and was most helpful.
I was pleasantly surprised when stripping out the spindle and bearings: after reading a lot of negativity about the quality of workmanship on the mini lathe, I found that the parts were pretty well made, although not awe-inspiring like some engineering, the parts are solid and certainly of acceptable quality. I had expected the Chinese bearings to be shot after about fifteen year's use, but both spun perfectly smoothly and with no trace of play, so in future I will have no hesitation in buying Chinese bearings.
Niels Abildgaard28/11/2019 12:01:30
470 forum posts
177 photos
Posted by COLIN MARTIN 2 on 28/11/2019 10:16:33:
UPDATE:
Can we see pictures of spindles side by side and bearings?
It will then be possible to construct the ultimate mini lathe spindle and I will be rich on saturday.
Something along these lines
Edited By Niels Abildgaard on 28/11/2019 12:07:04
COLIN MARTIN 228/11/2019 12:26:20
54 forum posts
The bearings are available from Arc Euro Trade and are a direct replacement for the standard ones. I'll try to post some pictures.
Ron Laden29/11/2019 09:44:02
2320 forum posts
452 photos
Hi Colin,
The changing of the bearings to better quality angular type I would think well worth doing but I cant quite see how they are going to improve rigidity regarding parting off issues. I can only go with the experience I had with my mini -lathe which had the factory fitted bearings which were not top quality but good enough. I never had a problem with the spindle and never thought it lacking in rigidity, the bearings were well adjusted there was no end float, no play and the fact the lathe worked well in normal turning operations sort of proved that.
However I did like you have parting off issues which in the end led to not using a parting tool larger than 1.5mm and I only parted off small parts, I wouldnt attempt anything large. So there was a lack of rigidity but where..? well I think it is a lack of rigidity in the cross slide, top slide and tool post and also a lack of rigidity between them (as a set) and the head. I had no problem with general turning the lathe worked well though I never pushed it too hard and I just based that on accepting that the mini-lathe is a lightweight machine and trying to keep within its limitations.
So what to about the problems with parting off, a few of the guys here on the forum suggested a rear tool post but it did mean making a larger heavier duty cross slide which is no small job. The cross slide on the mini is not really big enough to take a decent rear tool post so I bought a large chunk of cast iron and made a new one with longitudinal T slots and a rear toolpost, picture below.
The end result was a different machine when it came to parting off, I could user larger tools if needed and part larger sizes with no issues at all. Making a new cross slide wouldnt appeal to everyone of course but it was easily the best mod I did to the lathe.
My two penneth anyway and good luck with the bearings, hope they make a difference.
COLIN MARTIN 229/11/2019 10:04:00
54 forum posts
Hi Ron,
I think that you are completely right! I believe that the mini lathe lacks rigidity everywhere because it is quite poorly made and flimsy, but having said that, it is a terrific machine for the money. When comparing it to a bigger, studier lathe, which has so much rigidity in the head, bed and cross-slide, the mini lathe just has too much give in the components, so that the work tries to bend away from the parting tool.
I'm only changing the bearings because I have the spindle out, so it was worth trying the angular contact bearings. It was a mixed decision, because I have a spare pair of original bearings by KYO, which I could have used, but.....
Congratulations on your new cross-slide, maybe a new project for me?
Colin
Ron Laden29/11/2019 10:13:36
2320 forum posts
452 photos
Hi Colin,
I have moved up to a bit bigger lathe now but dont get me wrong I am not knocking the mini-lathe, never would as you say a great machine for the money. Mine taught me a lot and I did some good work on it, I did consider changing the spindle bearings on mine when I had the head stripped to change to metal gears but I put the standard ones back.
The heavier cross slide is a bit of a job but well worth doing should you ever consider it.
Ron
SillyOldDuffer29/11/2019 11:33:03
10668 forum posts
2415 photos
Posted by COLIN MARTIN 2 on 29/11/2019 10:04:00:
...I believe that the mini lathe lacks rigidity everywhere because it is quite poorly made and flimsy ...
Much truth in that, but it has to be said that many lathes struggle with parting off, and small ones are particularly troublesome. It's not that mini-lathes are exceptionally flimsy as such, rather that parting off is a severe test. Say a 2mm parting blade is used. The cutting edge is much larger than a point tool and bigger than average forces results. The parting tool operates in a slot liable to jam due to swarf or heat, and, if it dips for any reason, it's liable to dig in.
The forces applied by a 2mm cutter to a small lathe are the same as those applied to a bigger lathe : it's not surprising that big machines cope better.
But even big machines may not cope well with parting off. Anything allowing the cutting edge to dip will cause trouble. Worn beds allowing the saddle to rock, loose gibs (due to wear or maladjustment), not locking unused moving parts, excessive tool reach, jerky operator, bendy tool-post etc etc. Old Model Engineer magazines often discuss parting-off problems: no-one had a mini-lathe back then!
My WM280 can part off from the 4-way tool-post most of the time, but the cure-all is a hefty rear-mounted tool-post. The solid construction and position on the saddle of a rear tool-post enables any lathe to absorb significantly more force without dipping and vibration. Even so, it's still important to maintain a steady feed, to lubricate, and to clear swarf. I suspect a mini-lathe fitted with a rear tool-post would part off reasonably well, but fitting one means modifying the saddle. As space and the saddle design on a mini-lathe limits what can be done, not many are fitted with rear-tool posts!
I avoided parting off on my mini-lathe, preferring to remove the job to saw it, and then replacing to face-off. Wasted a bit of time, but a mostly suitable alternative. The lathe would part-off Brass OK, but Steel and Aluminium were more trouble than it was worth.
COLIN MARTIN 229/11/2019 11:40:02
54 forum posts
Yes, good points. I tend to avoid parting off if I can, just using it for thin wall tubes, but it would be nice to have more options. I watched a great video on YouTube recently that went into great depths on the subject and was really informative. The poster was obviously an experienced toolmaker and he detailed how much he struggled to part-off successfully.
HOWARDT29/11/2019 12:12:28
1081 forum posts
39 photos
I have a Sieg SC3, bought early 2016. Parting off with the machine as supplied is nye on impossible. A couple of years ago I replaced the bed slide keep strips with taper gibs, this helps but all the slides need clamping down. I have taken off the compound slide and replaced it with a riser for the tool post recently as I use the compound so little. When I fitted the gibs I was parting off 50mm steel as i didn't have a band saw at the time, From what I can see the main problem is with the cross slide width and fitting, as you part off the slide tries to rotate 90 degrees to the spindle causing the tip to move sideways and down to dig in. When I have time I shall make a better fitting gib and see if this helps.
Just my two penth.
COLIN MARTIN 229/11/2019 12:24:57
54 forum posts
I'm wondering if a saddle clamp would help?
