fizzy | 21/11/2019 09:47:08 |
![]() 1860 forum posts 121 photos | Hi - anyone know where I can get some - tried all the usual places but they only have piano wire or silver steel, but I need mild steel? Thanks
Mike Poole | 21/11/2019 10:06:58 |
![]() 3676 forum posts 82 photos | If you can tolerate a deviation from dead size would 2.8mm or 12SWG wire do the job? Mike |
old Al | 21/11/2019 10:07:15 |
187 forum posts | even in the good old days , this size was never commercially available |
John Haine | 21/11/2019 10:24:33 |
5563 forum posts 322 photos | Hmm...2.8 mm is 22 microns too big. 12 swg = 2.642 mm , 7/64 = 2.778 mm, 136 microns too small. But in BMS it was never to size anyway unless ground, often a bit smaller than nominal. Why is the size so important, can't you just use 3 mm or even 1/8? |
Rockingdodge | 21/11/2019 10:51:28 |
![]() 396 forum posts 111 photos | These guys advertise it - EKP Supplies |
fizzy | 21/11/2019 11:26:18 |
![]() 1860 forum posts 121 photos | 2.8mm or 12 SWG would do the job. Its to hold together 3d printed tank tracks at 1/8 scale. Stainless would be good but as mild steel is easier for me to work with thats what I need. I use EKP as a supplier to PSB but never gave them a thought - will take a look. Thanks.
Howard Lewis | 21/11/2019 12:36:50 |
7227 forum posts 21 photos | If all else fails, you will have the job of turning down some mild steel bar. Being 3mm raw material, presumably, one pin at a time close to the chuck! Looks like you are going into mass production! Howard |
fizzy | 21/11/2019 14:37:10 |
![]() 1860 forum posts 121 photos | Howard I think you may be correct - I hate turning long thin parts, never turns out well!
