File Handle | 19/11/2019 16:46:51 |
250 forum posts | I would welcome suggestions for the best way of holding brass rod when cutting say 12ba thread with a die. The best way I have found to grip the brass is a steel strip drilled and slit with a saw so that it can hold the rod when gripped in a vice. It works well, but does tend to distort the brass visibly. |
old mart | 19/11/2019 16:51:58 |
4655 forum posts 304 photos | A set of pin vises are handy when something small needs holding. |
JasonB | 19/11/2019 16:55:13 |
![]() 25215 forum posts 3105 photos 1 articles | drill chuck also works for me |
File Handle | 19/11/2019 16:57:06 |
250 forum posts | Thanks old mart. I have some, tried gripping them in the vice to hold the rod, but found that the rod slipped. They were a cheap set, is that the issue? Or can i modify them to increase their grip? I might be doing something wrong with them. |
File Handle | 19/11/2019 17:05:41 |
250 forum posts | Thanks Jason not tried a drill chuck, I have a very small one that I mount in my pillar drill chuck when using very small drills. However in some cases the rod will be longer than the depth of the chuck, needs thread at each end. But if it works I guess I could obtain a second one and drill through it. Will have another try with the pin chuck first to see if I can increase its grip. |
not done it yet | 19/11/2019 17:07:13 |
7517 forum posts 20 photos | I would fall back on the ER collet - either fitted on the lathe (ER16), or in a vise (with a Stevenson collet block) if my collets were small enough. |
old mart | 19/11/2019 17:24:37 |
4655 forum posts 304 photos | Pin vises sometimes require tightening with two pairs of pliers (and undoing). |
Neil Wyatt | 19/11/2019 19:25:08 |
![]() 19226 forum posts 749 photos 86 articles | Ironically you probably want the hardest brass you can get if trying to cut small threads - and a nice 'fresh' die. Neil |
old mart | 19/11/2019 19:29:18 |
4655 forum posts 304 photos | If you do a lot of threading with small stock, it would be worth getting a cheap ER11 collet with a selection of collets, or even an ER8, these small ones come with collets in 1/2mm increments, and can be bought cheaply on ebay. |
Howard Lewis | 19/11/2019 19:56:58 |
7227 forum posts 21 photos | My first thought was an ER collet, although 18 SWG is only 0.048" diameter, just a little over 1mm (1.219 mm if you want be more precise ) So ER 12 or 16 would seem the more obvious choices, rather than ER 20 or Er 25. Unless you envisage the need to hold larger work, in the future. Jason's suggestion of a small drill chuck is a good, and cheaper alternative to buying a ER collet chuck and collets; although they will always be useful at some time in the future. Using a drill, or collet, chuck allows the work to be done in the lathe, even if not under power. It should keep the thread on the centreline of the brass rod. This should minimise the chances of ending up with a drunken thread. Howard |
File Handle | 20/11/2019 16:10:40 |
250 forum posts | Thanks for all of the comments. Realised, when I checked, that i can use my 0-1/4" jacobs chuck by removing the 3/8 mandrel. Don't know why I didn't check this before as an option, thanks Jason. Will also see if I can apply pressure to get a pin vice to grip better. Die is pretty new, but a cheap carbon steel one. Brass rod / wire is a bit soft, but not sure were I can get harder from. Cheers Keith |
File Handle | 05/12/2019 12:34:12 |
250 forum posts | Just to add I used Jason's suggestion of using a chuck. Worked well, big improvement. I now feel stupid. it did occur to me to do this some time ago, but didn't thinking the centre of the chuck wasn't hollow. After Jason's suggestion I looked at my small chuck and realised that removing the arbor solved the issue. So thanks again. Keith |
