Colchester student feed issue
Simon Grist28/08/2019 13:31:34
3 forum posts
Hi All
I have just joined the forum as I recently bought a Mk1 (1953/54) Imperial Colchester Student. This will probably be the first of many basic question posts!
I have replaced the motor and added a VFD but I am having trouble engaging the sliding/surfacing feed, it will go into sliding feed only moving away from the chuck and when engaged in surfacing it just clicks and feels like something is worn or misaligned.
Does anyone have a diagram of this type of apron? I can only find the later plunger type.
The other issue I have is that the levers on top that change the gears seem to easily drop out of engagement, even under no load, is there something I can adjust to fix that?
Thanks in advance for any help.
Simon
Phil Whitley28/08/2019 20:24:16
1533 forum posts
147 photos
http://manuals.chudov.com/Clausing/Colchester-Student-Lathe-Manual.pdf
download this!
There is a ball and spring clutch in the feed drive shaft which clicks loudly if the feed is jammed. can you post up some pics of the machine. I also have a mk1 roundhead student.
Phil, East Yorks.
David George 130/08/2019 07:47:07
2110 forum posts
565 photos
Hi Simon welcome to the forum. Where are you, it helps if you give your locality as people local to you know what is available etc. What are your interests there are many people on here from bikers to steam enthusiasts and countless others.
David
Simon Grist03/09/2019 07:44:03
3 forum posts
Hi
I am in London in the UK, I got a diagram from the Colchester spares company and have now stripped the apt and the 2 feed shafts, it wasn't too mucky but the feed half nut is very worn. Just to be clear, should the feedshaft, the one with the keyway in it be turning all the time the motor is running? Anything I should look out for in the apron that would stop the power cross fed? I will post some pics in due course. Thanks
Ian Parkin03/09/2019 09:08:32
1174 forum posts
303 photos
The feed shaft will only rotate if the gearbox is set
the only one that doesn’t matter is the metric/imperial selector
and forward /reverse lever needs to be set to one or the other
but the feed shaft will /should always rotate if the above is done
Sorry just reread your post it will only run when the main spindle is turning
motor turning no...it may have a clutch
Edited By Ian Parkin on 03/09/2019 09:10:39
Simon Grist03/09/2019 09:39:32
3 forum posts
Posted by Ian Parkin on 03/09/2019 09:08:32:
It doesn't have a clutch, so just to be clear, if the motor/chuck is turning, so should the feed shaft?
It all seems ok in the apron, no worn gears or anything, I think I need to assemble everything properly and then see if it all works. for some reason the interface between the feedshaft and the cross feed was not meshing properly.
Ian Parkin03/09/2019 11:52:35
1174 forum posts
303 photos
Yes when the chuck is turning
if the forward /reverse traverse lever is set
if the gearbox is set the lift up handle one
if the abcd levers are set
then the feed shaft should turn
set the imperial/metric lever and the lead screw should also turn
Do you have a gearbox for screwcutting?
Edited By Ian Parkin on 03/09/2019 11:53:43
Howard Lewis04/09/2019 16:33:13
7227 forum posts
21 photos
Don't know the machine, but in simple terms, I would expect to find:
1) A lever, or levers, which allow the rotational speed of the chuck to be altered.
The VFD almost makes this redundant for most work
2) A Lever with three positions,
One where the feed shaft rotates in the same direction as the chuck,
The Middle one where the feed shaft does not rotate, and
The Third one, where the feed shaft rotates in the opposite direction to the chuck.
This will decide whether the Saddle moves towards, or away from the Chuck when the feed, or the half nuts are engaged.
Another lever will allow the drive to be directed to the Feed shaft, or to the Leadscrew. WHEN the lever, above (1), is not in the middle location.
4) If you have a lever or levers with positions, A, B, C and D; these should alter the speed at which the Feed shaft or Leadscrew moves relative to the chuck.
NONE of these levers should be moved when the chuck is rotating. You may need to rock the chuck to and fro, by hand, to ensure full engagement.
You ought to contact Tony Griffiths at Lathes UK (Contact him through the Lathes UK website) to see if he has a manual, or if you can download one, for your machine.
You are in London, so there should be a Model Engineering Society within a reasonable distance of you.
Go and Join it! There will almost certainly be a member who is prepared to come and help you become familiar with your machine.
That may prevent you damaging either the machine, yourself, or both!.
The new WiFi keyboard and mouse have developed auto send, it seems!
Edited By Howard Lewis on 04/09/2019 16:36:46
Edited By Howard Lewis on 04/09/2019 16:38:43
