Water pump dimensions
Garry Coles20/08/2019 17:44:24
121 forum posts
100 photos
Hi, On my 2 in D & NY Traction Engine that i'm building I seem to have a problem with the water pump dimensions. That or I missing something. The water pump plunger is described as 3/8" bore with a stroke of 1/2" . When I look at the eccentric drawing, the offset from the centre of the drive shaft to the centre of the eccentric is shown as 1/2" To me that gives a stroke of 1". If that is right, then the plunger dimensions are wrong because at a 1" stroke the graphite packing on the plunger will come out of the bore. Of course, I could be completely wrong. So can any one help me please.
Cheers Garry
MichaelR20/08/2019 20:09:27
528 forum posts
79 photos
I think this drawing is the D&NY water pump, there seems to be a difference in the pump ram and pump bore dimensions, looks like the pump bore is the wrong size
JasonB20/08/2019 20:26:42
Drawing says ream 3/8" and shows ram as 3/8".
1" stroke does sound too much for that engine, he did use 1" stroke for the larger horizontal pump but 1/2" stroke eg 1/4" offset is more likely. By comparrison my 2" Fowler is 3/8" bore x 3/8" stroke.
Edited By JasonB on 20/08/2019 20:41:07
Jeff Dayman20/08/2019 20:39:09
2356 forum posts
47 photos
Jason did you mean 1/2" stroke from a 1/4" offset eccentric? I think 1/2" stroke would work for the shown pump body, but not 1" stroke.
JasonB20/08/2019 20:40:48
Yes Jeff, altered it now
Jeff Dayman20/08/2019 20:46:24
2356 forum posts
47 photos
yes
JasonB20/08/2019 20:50:34
You only need to look at photos of other engines to see what the offset is, look at teh gear behind the eccentric, no way is it offset by 1/2"
Garry Coles20/08/2019 22:26:09
121 forum posts
100 photos
Thanks for the replies.yes I will now go ahead with 1/4" offset on the eccentric. The eccentric dimensions on the drawing are wrong then. Thank god for that. I've fabricated the body, but did not start on the eccentric yet. smiley
JasonB21/08/2019 08:55:46
This video shows the pump quite well, about half way through you can see that the ram lifts a little more than it's diameter so 1/2" stroke.
Garry Coles21/08/2019 09:12:34
121 forum posts
100 photos
Thanks for the help Jason. yes
