Changing hand wheels
John Kinnane | 20/08/2019 07:20:45 |
44 forum posts | hi I would just like to know if anyone has changed the hand wheels on their mill or lathe. I have a Sieg SX 2.7 Mill and a Sieg SC 6 metal lathe both of which I would like to change the black cheap looking hand wheels for a bit larger spoked wheel with the key cut into them. There are a lot on EBay but it would be great if somebody has already done and could advise me thank you John |
john carruthers | 20/08/2019 08:22:05 |
![]() 617 forum posts 180 photos | Have you asked Arc Euro? |
RobCox | 20/08/2019 09:02:30 |
82 forum posts 44 photos | When I renovated my elliott mill I junked the original handles as they were plastic and looking tatty. I replaced them with some nice cast iron ones from wdsltd.co.uk (usual disclaimer, no connection, just a satisfied customer). They do a range of sizes, materials etc. Just one word of warning - the keyway will cost you! I bought mine without a hole as I needed to bore it to fit an imperial shaft and cut a keyway on the lathe (doubleboost style). As an example, a 100mm dia cast iron wheel is £11 + VAT without keyway, £25 + VAT with! Rob |
Howi | 20/08/2019 09:13:50 |
![]() 442 forum posts 19 photos | i changed mine on an SX2P mill recently, got two 100mm cast iron wheels from China for not very much. Nice quality cast iron, easy to machine. drilled and reamed to suit and turned down the boss to fit the ring with the markings on. Wheels came very quickly considering from China and would have coizst me more than double in the uk. Wish I had done it sooner!
not done it yet | 20/08/2019 09:32:12 |
7517 forum posts 20 photos | I have two hand wheels to change. A larger diameter one for the table of my mill, to reduce the effort, and the tailstock wheel on my lathe because it does not have a handle. Neither are difficult but it is just getting round to it as both are functioning at present. Just get one you like, in the correct diameter, but with the correct boss, or one that can be altered. I would not recommend cutting a keyway on the lathe unless you have the correct tool to use with the saddle locked (not seen the doubleboost video - he now sensibly uses broaches?). Drilled, before boring, and cleaned up later is an option. Do get one with a loose handle - I find fixed ones are not as nice in the long run - however shiny they might be. I intend making one handle from scratch and modifying the boss of one I already have - when I get round to it! Shaper will be used to cut the keyway as it is built for that type of job. |
John Kinnane | 20/08/2019 10:10:41 |
44 forum posts | I would like to thank all the people that replied to me and have had some great advice thank you John Kinnane Tasmania Australia |
Howard Lewis | 20/08/2019 10:40:35 |
7227 forum posts 21 photos | Am sure that Arc Euro will help if at all possible. Since you have a Seig machine, it is likely that they can Howard |
not done it yet | 20/08/2019 11:06:22 |
7517 forum posts 20 photos | Posted by Howard Lewis on 20/08/2019 10:40:35:
Am sure that Arc Euro will help if at all possible. Since you have a Seig machine, it is likely that they can Howard I doubt it is economic to send hand wheels to the other side of the Earth? China is much closer and better (subsidised?) postal rates! |
old mart | 20/08/2019 16:27:09 |
4655 forum posts 304 photos | I am thinking of getting one of the 125mm wheels from RDG on ebay UK, 351115443777. It has a 12mm bore that could be increased quite easily. The Tom Senior light vertical X axis has a nice balanced handle, but I prefer a round design that can be held in both hands at once comfortably. |
Bazyle | 20/08/2019 18:23:06 |
![]() 6956 forum posts 229 photos | How about a verhicle steering wheel. You could get a bit of momentum up for a smooth feed and if you put a scale round the periphery you could set to tenths of tenths. |
MadMike | 20/08/2019 18:39:23 |
265 forum posts 4 photos | Ausee who advertise on the RH side of this page sell Seig machines and are based in Australia. I am sure that Ketan at Arc Euro would recommend them. |
