Alistair Robertson 1 | 12/08/2019 19:25:01 |
154 forum posts 6 photos | I have a Denford Novamill and to gain a bit more room in the workshop I altered the central pivoting of the Perspex "bubble" top cover to a rear hinge. This allowed me to place the machine against the wall saving about 200mm space. I was going to fit a couple of struts that lock when they are extended then release when you push them up again to allow the guard to lower. I measured up the length I would need and went to my local hardware store to be met with stony silence when I explained what I was after. I had fitted the same sort of strut to a previous machine for a customer a few years ago. "You can't get anything like that" I was told, But I had bought them previously so I went home and looked up my old paperwork as to where I had bought them. I had bought them from a different shop so a few days later I went to town and strode confidently in to the counter to be told "Never seen anything like that!" I showed them my old invoice which said "Self Locking Strut" but no part number and they also said "Never seen them!!" I have looked on the Internet but I am not sure what the correct description should be! They are like a drawer slide but with no balls (I think) and when they fully extend a bit of metal pops out of a square hole locking the strut in place. Push the strut further up and it releases. Can anyone give me a correct description as I can't remember what I asked for about 10 years ago! |
Vic | 12/08/2019 19:38:05 |
3453 forum posts 23 photos | Hi Alistair, is there anything Here that may do the job? |
Brian G | 12/08/2019 19:40:24 |
912 forum posts 40 photos | How about these? **LINK** Brian |
MichaelR | 12/08/2019 19:47:14 |
![]() 528 forum posts 79 photos | Hold Open Stay Here may be what you are looking for. |
Robert B | 12/08/2019 20:58:59 |
20 forum posts 6 photos | Posibly these? https://www.catchesandlatches.co.uk/lid-stays-hinges/ |
John Hinkley | 12/08/2019 21:37:39 |
![]() 1545 forum posts 484 photos | I seem to remember that my Frogeye Sprite had a similar strut arrangement to support the open bonnet. Replacements are available, but at a price ( around forty quid !). Could you not use a gas strut such as are used for tailgate lifts? Plenty on eBay in various sizes and specs for under a tenner. John |
Nigel Graham 2 | 12/08/2019 22:39:17 |
3293 forum posts 112 photos | I would not use a car gas-strut to hold a small plastic machine-guard. They are designed to balance a far heavier mass than that, so would be physically very hard to handle. Some machines, including my Myford VMC, use a basic toggle: just two links pivoted together at mid-point when both are in line. Pushing the joint while closing the cover down slightly makes the links go past alignment by a couple of degrees of so, against a small stop on one of them. |
Clive Foster | 13/08/2019 00:20:44 |
3630 forum posts 128 photos | The friction slide thingies used on modern windows instead of hinges ought to be well up to the support job. I have a stash of used ones in the "gotta be useful" box. If you fancy trying the idea PM me and a pair are yours for postage costs. The locking struts in Brians link are effective but, if the ones I saw are the same model, quite hefty. Eurofit offer a variety of lid stays :- **LINK** including light duty gas struts, smallest is 50 newtons force, about 11 lb. The ordinary folding desk stay like this :- **LINK** can quite easily be modified to work as an over centre toggle type support as described by Nigel. I did one many years ago which worked OK. Darned if I can remember exactly what I did tho'. An ordinary drawer slide will do the deed just fine if you ass a sprung clip. In principle its easy to come up with a two position clip which releases if you push the lid beyond its holding position and re-arms ready to support the lid next time as you swing it shut. In practical its probably more works than the job is worth. Clive |
Alistair Robertson 1 | 13/08/2019 09:36:23 |
154 forum posts 6 photos | Hi, All. Thanks for all the valuable information. I have bought a pair of the type suggested by Brian G from RS. Why I didn't look there before i don't know. I ordered some bits and pieces from them last week! I didn't want to use a gas strut as when they have to be compressed to "go overcentre" they put a big strain on the perspex cover which weighs about 25 Kgs. as I well know when I knocked out the plastic tube I was holding it up with and had to visit the hospital for a neck X-Ray. It was sore for more than a week. The pair I bought a few years ago were not the same as the Camloc I have bought from RS they were more like a drawer slide that locked when extended. |
Nick Hughes | 19/10/2019 11:24:13 |
![]() 307 forum posts 150 photos | A bit late, but I just came across these when searching for something completely different and remembered this thread:- From here:- Small Bonnet Stay Auto-Close |
