Vic | 11/08/2019 11:10:57 |
3453 forum posts 23 photos | I ordered a long series slot drill from the auction site. Two standard ones turned up today ... I won’t give them bad feedback because I suppose two short ones equals one long one! |
Kiwi Bloke | 11/08/2019 11:16:14 |
912 forum posts 3 photos | Perhaps the same helpful folk would send you two 3mm dia end mills if you ordered one of 6mm dia. |
Vic | 11/08/2019 11:41:46 |
3453 forum posts 23 photos | Funnily enough it was a 6mm I ordered. They will get used and at only a couple of quid it’s not an upset. I’ve found a UK supplier doing them for about £9 so I’ll add that to my next order for inserts. |
not done it yet | 11/08/2019 12:07:38 |
7517 forum posts 20 photos | Here’s hoping they are not 1/4” instead of the metric! 19mm/3/4” may not be too bad for most things, but 16mm/5/8” can definitely mean a nuisance difference. |
peak4 | 11/08/2019 16:49:21 |
![]() 2207 forum posts 210 photos | Whilst I was still at work, one of our planners ordered me enough cable for a 130m cable run of 16 core co-ax; Stores sent me a 100m drum plus a separate 30m coil. Ho Hum. Bill |
